Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
Need some tuning help
Old Sep 5, 2012 | 11:11 PM
A.Delaney's Avatar
Car: 92 camaro
Engine: 409 sbc
Transmission: TH 350
Axle/Gears: 4.10, mini spool, camaro housing
Well I got my 410sbc back in the car and running. Problem Im having is the engine will back fire once it gets a little heat in her. Fresh rings and open headers. What am I missing? Too lean? Timing is locked out at 36deg I believe. I didnt set it. My buddy did. Would mufflers help since there is no back pressure. Its got a 4150 carb on it also.
Old Sep 6, 2012 | 07:38 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Need some tuning help
When does it backfire? Under load? When decelerating?
Could be too lean. Could have an exhaust leak around the manifold gaskets. Probably needs some back pressure. Exhaust valve adjustment might be a little tight.
Old Sep 6, 2012 | 09:45 PM
A.Delaney's Avatar
Car: 92 camaro
Engine: 409 sbc
It backfires while idleing no load.
Old Sep 6, 2012 | 09:54 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Check the timing. Check the valve lash.
Old Sep 6, 2012 | 09:59 PM
A.Delaney's Avatar
Car: 92 camaro
Engine: 409 sbc
Ok thanks. It doesnt do it cold. Only once it gets warm.
Old Sep 18, 2012 | 09:40 PM
A.Delaney's Avatar
Car: 92 camaro
Engine: 409 sbc
Well im still fighting this issue. I have exhaust on the car now. Timing is set at 37deg. New plugs. Carb tuning checked. One thing though was the header temp. 7 of the header tubes all had the same temp except number 4. It was 40 degs hotter than the rest. We loosened the exhaust valve some. Temp came down a little. The cam is hydraulic not solid lifter. Is it possible the lifter is bad?
Old Sep 18, 2012 | 09:44 PM
A.Delaney's Avatar
Car: 92 camaro
Engine: 409 sbc
Also it breaks up under hard acceleration. Maybe it is to lean on the top end. The backfire is around idle though.
Old Sep 18, 2012 | 10:10 PM
AlkyIROC's Avatar
Car: 87 IROC L98
I don't know if it's an option but try a different distributor. What kind of distributor are you using. I know with crank trigger systems, if the gap is too great, you'll have the same kind of problem where the ignition breaks up under load. I was having a problem like that a couple of years ago and I needed a new crank pickup. Maybe the pickup in the distributor is on it's way out.
Old Sep 18, 2012 | 11:00 PM
A.Delaney's Avatar
Car: 92 camaro
Engine: 409 sbc
Its an MSD Pro Billet brand new. MSD 6al and a blaster HVC coil.
Old Sep 19, 2012 | 06:00 AM
DIGGLER's Avatar
compression check? lash too tight?
Old Sep 19, 2012 | 06:41 AM
pancherj's Avatar
Car: 1990 IROC
Engine: Rebuilt L98 with H/C/I/Carb
Transmission: TH350 with ATI Treemaster
Axle/Gears: 7.5 with 4.10's
What lifters are you using? Some are designed for a lot less preload than others. On my comp lifters, they call for 1/8 turn. I usually set them a little less than that. It sounds like you found the problem (lifter preload). I would go back through and do all of the valves.
Old Sep 19, 2012 | 09:06 PM
A.Delaney's Avatar
Car: 92 camaro
Engine: 409 sbc
The cam is a comp 305H Hydraulic cam and comp lifters. I forgot to mention. We removed this engine from my buddies car. It ran great in there. It sat for about a year before I got it. We disassembled it and put in new bearings and piston rings. The engine hardly had much run time before it sat for a year. Stuck it in my car and now this. The entire setup is exactly the same that ran great before. We will check the valves again.
Old Sep 19, 2012 | 09:11 PM
A.Delaney's Avatar
Car: 92 camaro
Engine: 409 sbc
I will check compression also.
Old Sep 20, 2012 | 09:21 PM
A.Delaney's Avatar
Car: 92 camaro
Engine: 409 sbc
well I got between 185 and 190 except number 4 was 175 on the compression test.
Old Sep 20, 2012 | 10:23 PM
AlkyIROC's Avatar
Car: 87 IROC L98
That could be from valve lash. It's not great but it's also not a dramatic difference. Squirt some oil in the cylinders and do it again.
Old Sep 24, 2012 | 09:28 PM
A.Delaney's Avatar
Car: 92 camaro
Engine: 409 sbc
Well after all that messing around it turned out to be a bad MSD box. We got it fixed and running good now. Thanks fellas.
Zell1luk
Sep 29, 2015 10:36 AM
