Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
Rear coilover spring rate?
Old Oct 12, 2012 | 02:28 PM
itsjustabird's Avatar
Car: 91 firebird
Engine: sb2.2 headed sbnos
Transmission: tsi glide
Axle/Gears: 4.30
Anyone do a coil over on the rear? What spring rate and length? Going on a 3870 series afco shock
Aaron
Old Oct 12, 2012 | 07:02 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Rear coilover spring rate?
I run 110 pound springs in my car. I've run 130 pound with no problem but wanted a softer spring so the shocks could do their job. I have some 150 pound springs but know they would be too stiff.
Springs hold the weight of the car up. You only need enough spring rate so that they'll compress to a proper distance for the shocks to work. The shocks do all the work as the weight on the spring allows the shock to extend and compress. The valving in the shock controls how much and how fast that movement is.
Too stiff a spring and the function of the shock is greatly decreased since the weight on the spring doesn't compress the shock enough. Too soft a spring and the shock gets compressed too far.
With a coil over system, you can always adjust preload to raise or lower the compressed shock length. The shock mount can then be adjusted to set the car's ride height. There's a ballpark number to shoot for. If a shock has 5" of travel, the weight on the spring should compress the shock about 2". Without knowing the unsprung weight that sits on the shocks, you'll never know the proper spring rate to use. You can't just weigh the car on the tires because you're also weighing the tires, diff etc. Rear car weight minus about 500 pounds should put you close to the unsprung weight.
Old Oct 13, 2012 | 12:23 PM
Car: 91 firebird
Axle/Gears: 4.30
Thanks stephen
Old Oct 13, 2012 | 09:45 PM
1BADRZ28's Avatar
Car: 1982 Camaro
Engine: 555 BBC
Transmission: TSI Glide
Axle/Gears: Aluminum Moser 3.89
I run afco big guns and run 14x150. I tried 125 and it was too light
Old Oct 18, 2012 | 01:03 PM
Car: 91 firebird
Axle/Gears: 4.30
any pics of your rear suspension set-up? did you use the bolt in style or standard style?
Old Oct 18, 2012 | 01:36 PM
1BADRZ28's Avatar
Car: 1982 Camaro
Engine: 555 BBC
Bolt in since they give the stud option
Old Oct 18, 2012 | 05:58 PM
Car: 91 firebird
Axle/Gears: 4.30
Did you use the panhard clevis on the bottom to mount it? if so did you use bushings to keep it centered?
Also wouldnt mind input on front spring for coil overs. Tried 175 first seemed like too much and didnt compress much now with 125 they are compressed a fair bit but doesnt seem to transfer very well. stock block sbc with a plate and all the usual stuff removed.
Old Oct 18, 2012 | 06:30 PM
DIGGLER's Avatar
where is your upper shock mounts? still below the floorboard?
Old Oct 18, 2012 | 08:02 PM
1BADRZ28's Avatar
Car: 1982 Camaro
Engine: 555 BBC
No spacers are needed when using a Clevis. I had 175lbs up front with an aluminum headed sbc.
My coilovers are mounted in the stock shock location both on the rearend and upper shockount.
Old Oct 18, 2012 | 10:02 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
running 12x170 in the front and 10x150 in the rear on my car
Old Oct 19, 2012 | 06:57 PM
Car: 91 firebird
Axle/Gears: 4.30
Xpndl3 is urs coilover or on the axle
Old Oct 19, 2012 | 07:08 PM
xpndbl3's Avatar
Car: 1984 Z28
rears are the wolfe racecraft kit, fronts are racecraft coilovers.
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
sailtexas186548
Aug 26, 2015 03:32 PM
Dialed_In
Aug 20, 2015 01:45 PM
