Hoosier 275's
Car: 1987 Camaro
Engine: 406
Transmission: Powerglide
Axle/Gears: Moser 31 spline / 4.86
Hoosier 275's
What air pressure should I start at? how much is too less, or too much. I've heard around 16 lbs? Put on a used set for a charity/toy race for this coming Saturday. Never run radials before. 3200lbs, one month ago on 29.0x10.0 slicks went 6.58 1.400 60'.
Engine: Vortec 4200 Inline 6 PT70 Turbo..
Transmission: 4L65E
Re: Hoosier 275's
I've tried 14-22. A friend swears by 22psi but he runs 10.90's @ 122.
I stuck with 16psi hot for many true street passes and had consistant 1.41-1.43 60's. 3450 convertible car with a glide/3.73's. It went 140mph but was geared for about 155. 4500rpm transbrake launches.
Goodluck! They are really stable!!
Car: 84 camaro
Engine: HRE 355
Transmission: th350
Axle/Gears: 4.56
Re: Hoosier 275's
Start at 18. I run 22 psi and run 1.32 in 60' no issues. I have 52% weight on nose...and weigh 3095 total...if youre more on the nose try a little less air
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: Hoosier 275's
run my 295/55 m/t at 18 hot, which is around 16.5 cold. Buddy runs the hoosiers at no more than 17 cold or he blew them off. His car is 90 pounds lighter on the nose than mine also.
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
Re: Hoosier 275's
yeah, 18psi is what i ran. the new MT seems to be a better tire though
Car: 1987 Camaro
Engine: 406
Engine: 7.0L
Re: Hoosier 275's
ah, i gotya. they don't have a great amount of life in them to begin with, so i hope you get a couple passes out of them. they're a great tire, but i think i only got 40ish passes out of them. i hear the m/t is the same way.
Car: 84 camaro
Engine: HRE 355
Transmission: th350
Axle/Gears: 4.56
Re: Hoosier 275's
the m/t is 9lbs heavier though....i think that matters unless youre a 1300hp x275 guy. lol
the hoosiers on my buddies 9.50 car last about 65-75 passes...all they need is a quick burnout to be perfect.
i had 75 passes on the OLD m/t tire before it was just done...wouldnt barely try to hook anymore.
Car: 1982 Camaro
Engine: 555 BBC
Transmission: TSI Glide
Axle/Gears: Aluminum Moser 3.89
Re: Hoosier 275's
18.5 psi cold. 1.19 60' on the rears. I get tire shake below 17.5 and usually got 20 passes on Hoosiers because the resale sucks with the grooves are almost gone. New MT I got 50+ and still had good reslale becuase of the deep grooves
Car: 1987 Camaro
Engine: 406
Re: Hoosier 275's
Well first pass I set the tires on 16.5, did a good burnout, launch on 3400 and it shook hard with a 1.50 60; and ran 6.71. Went up to 18 psi, dropped launch to 3100, went 6.51 6.494 6.491 6.487 .... 1.402 1.398 1.395 1.400 60's Got one video of it.
Radial tires pass
Radial tires pass
Car: 84 camaro
Engine: HRE 355
Transmission: th350
Axle/Gears: 4.56
Re: Hoosier 275's
You know...if you switched to a lightweight th350 you could prob go 1.33 or 1.35 in 60' and drop a tenth or two from your et easily.
Car: 1987 Camaro
Engine: 406
Re: Hoosier 275's
For the pro tree racing I do, the glide is best trans. I tried a 1.98 first gear in my glide and didn't like it. Hit the tires too hard.
Car: 1984 Z28
Re: Hoosier 275's
how long did you run out that burnout to call it a "good" one. Typically we ran them until we saw smoke initially then released the line lock. No john force burnouts needed on radials at all.
Car: 1987 Camaro
Engine: 406
Re: Hoosier 275's
Well on a fresh set they might not need that much, but I was told to heat them up so I did, lol. Usually my slicks will start to chatter right out of the water but these things just kept on spinning. It was just a charity race and a memorial race for a man who worked the track for over 18 years and died out there a month ago when a Dragster backed over him on the line. I was having fun actually getting to run the car wide open for a change.
Beeman
Aug 31, 2015 07:40 PM
