Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
finally got into the 8s! on radials
Old Jan 1, 2013 | 08:21 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
well went to the track and finally got this past years goal done on the 30th lol. I went 8.98@155 on a 275/60 drag radial. motor is still with a stock truck 350 block. I was selling it (https://www.thirdgen.org/forums/engi...s-my-drag.html) but no one wanted it lol. so went and made some fun passes. itll run a 8.6x@159-160 if i got the front end down.. which i did on the last pass but third gear gave out i believe
Old Jan 1, 2013 | 08:33 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: finally got into the 8s! on radials
Pretty stout run! Even with the slight 'pedaling!!
Old Jan 1, 2013 | 08:35 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
awesome video. Man she is getting it done..
Old Jan 1, 2013 | 08:42 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Damn fine work sir!
Old Jan 2, 2013 | 08:06 AM
Shagwell's Avatar
Car: projects.......
Nicely done!
Old Jan 2, 2013 | 08:35 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Wow that car has progressed a long way! Congrats
Old Jan 2, 2013 | 11:41 AM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
man, wow that's awesome! what is the raceweight?
Old Jan 2, 2013 | 12:36 PM
86iroc2try's Avatar
Car: 84 camaro
Engine: HRE 355
Transmission: th350
Axle/Gears: 4.56
Way to go!!
Old Jan 2, 2013 | 04:37 PM
DIGGLER's Avatar
man thats awesome! you should go to a glide. same trouble i had with the wheelstands.
Old Jan 3, 2013 | 07:48 AM
Shagwell's Avatar
He'd be ahead of the curve if he just put a swapped the VB to a "2nd gear leaver" so that he could put more rear gear in & launch in 2nd. - A lot of the fast radial cars are figuring that out now, it's especially helpful with a small-block/nitrous combo that doesn't have enough HP to really pull the steep rear gears up top that are required down low to control the launch.
Old Jan 3, 2013 | 07:54 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Couldnt you just leave on a progressive hit and tweak suspension abit more? Does it have front end limiters?
Leaving in 2nd and just adding more rear gear will lower the launch ratio but that more gear will run out of top end rpm. Not sure what you turn for rpm but you may start to over rev and need to stay on limiter for abit at the traps
Old Jan 3, 2013 | 11:15 AM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
i did mess with the progressive and thats how it left so well on the last pass. however that track I was at is hit or miss. the car usually leaves perfect but with that track you have to loosen up the suspension a lot to get it to hook.
the Th400 is perfect for this small motor i have. it really doesnt have the power like shagwell said to run a glide.
Old Jan 3, 2013 | 12:07 PM
Shagwell's Avatar
OSW is a lot more miss than hit.....
The longer you have to delay the progressive the more you are leaving on the table.
Many of the glide loving drag radial guys are starting to figure out the typical 1.80 low glide is not the ticket, especially with nitrous combo that doesn't have the back-half HP of a boosted motor. - Several companies working on steeper glide ratios, but LOTS of guys already switching over to the 2-speed "turbo glide" type trans.
Limiting front travel is often a band-aid for a radial car, better off if you can let it hang but slow it way down with the shocks so that it takes 1+ seconds before getting to full droop. Allows enough transfer at the hit w/o having any abrupt shock of weight that is likely to break the tires loose after the initial hit.
Old Jan 3, 2013 | 12:50 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Nice tips thanks. Plan on trying a 275 radial with a brake on my turbo car once its back together
Old Jan 3, 2013 | 01:45 PM
itsjustabird's Avatar
Car: 91 firebird
Engine: sb2.2 headed sbnos
Transmission: tsi glide
Axle/Gears: 4.30
Is that stilletos old car?
Old Jan 3, 2013 | 02:32 PM
Shagwell's Avatar
Unless he had a picture from back when "stilletto" started for the pic at the end of the video then I wouldn't think so. - That car was mostly white with black on top.
Old Jan 3, 2013 | 02:48 PM
Car: 91 firebird
Axle/Gears: 4.30
I just remembered that Chris said it had sold locally.
Old Jan 3, 2013 | 03:59 PM
DIGGLER's Avatar
2 speed th400 will work good too. if you tried everything and are having to remove power to keep it off the bumper, you can stand less gear off the line, imo.
as stated also, front shocks are a BIG part of it. limiters are a band-aid.
Old Jan 3, 2013 | 04:05 PM
DIGGLER's Avatar
the nitrous guys were never running out of gear. some of these guys have been running a 3.42 gear or less on the th400 cars.
there is one person that has posted on here before that had the th400 figured out pretty dang well in x275. he was running a 4.10 gear and had it down into the 1.23-1.25 range. he has since switched to a glide and last i talked to him he said the car liked the change.
Old Jan 3, 2013 | 05:26 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
stilleto is my budy chris. no we have two seperate cars. yes the new motor i build will be using a turboglide. those transmissions are awesome
Old Jan 3, 2013 | 05:27 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
limiteres arent just a band aid imo. on these cars struts that actually work well are very very very expensive.
Old Jan 3, 2013 | 07:52 PM
DIGGLER's Avatar
yup, a band aid because good shocks cost alot. i know, i have limiters on my car too. lol
you dont necessarily have to buy afcos or santhuffs.... if you can find a talented shock tuner, you can get better results working with a cheap shock than an out of the box expensive shock.
the better setup is to have all your travel available to you, and controll the extension. with limiters, the car comes up too fast and snaps to a dead stop. if you could slow down that first 2-3" of travel before they hit the limiter, the tires might not even come off the track.
Old Jan 3, 2013 | 07:57 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
How bout a bunch of rubber bands?
Old Jan 3, 2013 | 09:53 PM
RS Chris's Avatar
Car: 1991 RS
Engine: 5.0
^^This guy.
So I guess no more Mexico racing for you Kowboy?
Old Jan 4, 2013 | 07:38 AM
Shagwell's Avatar
I use the HD rubber bunge cords........apparently not enough of them in the mustang though........
Old Jan 4, 2013 | 12:24 PM
Car: 91 firebird
Axle/Gears: 4.30
Kowboy if you dont mind can you shoot me a ball park on what trz charged for a cage?
Also you plan on running any of the fl ultra st races?
Old Jan 13, 2013 | 03:05 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
i will be running ultra street when i am not working. I dont remember what the cage cost, but i can call and find out. I do know they are very busy right now lol
Old Jan 13, 2013 | 03:34 PM
Car: 91 firebird
Axle/Gears: 4.30
Yeah I am curious! If Ican get a cage done this year($$$?) then I will run ultra should be able to go 5.20-5.30s
Old Jan 13, 2013 | 03:44 PM
tzim350HO's Avatar
Car: 1991 Trans Am GTA
Engine: 350 carbed
Axle/Gears: 7.5 10 bolt 4.10
http://www.youtube.com/watch?v=BS8E3PVf7_U
Are you running a 3 speed auto in that car? Sounds like its revving to the moon! What gear do you run in that car?
Old Jan 13, 2013 | 03:56 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
3.42 gear th400. i think transmission let go right after the pass. I no longer have reverse or third gear lol
Old Jan 13, 2013 | 03:58 PM
tzim350HO's Avatar
Engine: 350 carbed
You must be pulling some high rpms with that
Old Jan 13, 2013 | 03:59 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
shift it at 6800
Old Jan 13, 2013 | 08:44 PM
86iroc2try's Avatar
Car: 84 camaro
Engine: HRE 355
Transmission: th350
Axle/Gears: 4.56
Thats a cool car...i know my buddy switched to santuffs and it was total night and day even with the limiters!
Too expensive for me...but all of the local x275 guys run them now for that reason. Im sure a qa1 valved to your car would be just as effective!! Good luck when the trans is fixed!!!
Old Jan 14, 2013 | 03:55 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
Thanks^^^ i already got santhuffs on the way. lol car will be running ultimate street again this february and then ill be in x275 the end of the year. Well end of year running both classes
Orr89RocZ
Feb 13, 2016 10:04 PM
jtmiller92
Nov 4, 2006 07:24 PM
Dialed_In
May 31, 2006 10:01 AM
Nic
Theoretical and Street Racing
Oct 2, 2002 05:27 PM
