Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
Pictures of door panels in street/strip or racecars?
Old 02-11-2014, 01:17 PM
unknown_host's Avatar
Car: 1989 Iroc Z L98
I am taking a bunch of weight out of my doors, got inspired by a post I read last night from Matt Walter.
One question I have, the door panels seem way heavier than I thought they would be. What have you guys done for door panels on street/strip or racecars? Non stock please. I would even consider ditching the stock armrest if I had something to pull while the windows are up.
Pics would be great.
Thanks!
Old 02-11-2014, 11:14 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
Re: Pictures of door panels in street/strip or racecars?
Subscribing!
I took off my door handles for my door bars to fit better.
I'm going to paint the silver metal tab to black and put black plastic caps to cover the holes in the door skin.
Old 02-12-2014, 07:28 AM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
LB9, if you take the door panels off, those tabs for the arm rest are just riveted on, and it can come off. then make your covers or caps from the inside of the panel.
I'm running stock panels at the moment. i'm really considering making a move to some carbon fiber sheet honestly. i've been thinking about it for a while.
Old 02-12-2014, 07:58 AM
mw66nova's Avatar
Engine: 7.0L
Seth, take a look at this thread i posted up a few years back on the door project that i abandoned. i think i'm going to revisit this:
https://www.thirdgen.org/forums/orga...ch-weight.html
Old 02-12-2014, 01:33 PM
Thanks Matt, will check it out in a second . I guess some Porsches and European cars come with pull straps instead of armrest/pull bars from the factory:
I am totally doing this the armrests are heavy.
Old 02-12-2014, 02:01 PM
mw66nova's Avatar
Engine: 7.0L
i like that...i think i'll look into that too.
Old 02-12-2014, 09:12 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Lol! I just weighed both of my armrests from my 91 GTA, together they are 5lbs.
Old 02-12-2014, 09:17 PM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
wow! never really thought they weighed that much. it all adds up though.
Old 02-14-2014, 08:27 PM
tvc 15's Avatar
Car: 88 rs
Engine: ls1
Transmission: t56
Axle/Gears: moser 4:10
Not sure if these are much lighter than stock. I made them out of .040 aluminum.
Attached Thumbnails Pictures of door panels in street/strip or racecars?-done-010.jpg
Old 02-14-2014, 10:32 PM
mw66nova's Avatar
Engine: 7.0L
That looks way better than I thought it would
Old 02-15-2014, 01:38 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
The pull handles are a very European thing... Magnus Walker does something similar on his cars... but it's a good example of a super spartan door that looks good.
http://digitaldtour.files.wordpress....4/dsc_0056.jpg
http://www.roadandtrack.com/cm/roada...1_STR_2351.jpg
And that's inside this car, which is pretty much his streetable track car.
http://digitaldtour.files.wordpress....2/dsc_0656.jpg
Old 02-15-2014, 05:14 AM
mw66nova's Avatar
Engine: 7.0L
I gotta tell ya, roads ace guys always have the cleanest race interiors
Old 02-22-2014, 02:09 PM
Wow that looks amazing.
Old 02-22-2014, 02:10 PM
http://youtu.be/s5Cs1CkrIlE?t=18m10s
Man those look good too, a lot to go on in this thread thanks for the replies. I was in Oklahoma for a week, getting caught back up.
Old 02-22-2014, 02:18 PM
Now I am wondering what to make my replacement door panels out of... I liked aluminum but all I have access to are tin snips really for doing sheet metal work.
Old 03-02-2014, 10:03 PM
mw66nova's Avatar
Engine: 7.0L
We got the driver's side door lightening done. 15lbs saved out of the door itself. the c-channel crash bar is 12lbs by itself. i highly recommend removing it if you have door bars in your roll bar.
this is the passenger's side door, which i haven't touched yet.
here is our driver's door in the "after" state.
Old 03-03-2014, 10:29 AM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
You can cut aluminum sheet using a jig saw. Then finish the edges with some sort of vinyl material.
Old 03-03-2014, 10:35 AM
Dialed_In's Avatar
Trim options:
http://www.mcmaster.com/#trim-molding/=qxnhzw
Good stuff Matt! Makes me want to pull the crash bars lol, too bad I don't have a cage . Are you counting the actual door panel in your 15 pounds or are you planning on putting it back on?
Old 03-03-2014, 11:02 AM
Ok so here is what I wound up doing:
Before Cutting out:
After Cutting out:
Aluminum Test Fit (I used the old door panel as a template):
Everything Mocked up:
Bought a pair of these in grey to replace the stock arm rest:
I will post a real finished pic once everything is mounted.
Old 03-03-2014, 11:27 AM
Dialed_In's Avatar
Very nice!
Old 03-03-2014, 12:03 PM
mw66nova's Avatar
Engine: 7.0L
seth, is that ozite carpet over the aluminum?
Old 03-03-2014, 12:07 PM
mw66nova's Avatar
Engine: 7.0L
does anyone know the exact year of the c-channel vs round bar crash bar? 87 and older have the c-channel for sure. 89+ has round bar for sure. i've never seen an 88 door (well, not with enough attention to detail anyway). it happened in the 88/89 years i believe.
Old 03-03-2014, 12:41 PM
Walmart sells generic, lightweight black carpet for $9 a roll. The carpet covering the entire door panel weighs next to nothing.
Old 03-03-2014, 12:43 PM
Originally Posted by Dialed_In
Very nice!
Thanks I just want it to not stick out lol. Thanks for sharing those links btw.
Old 03-03-2014, 01:05 PM
Mrbanados's Avatar
Car: 84 Camaro z28
Engine: 355
Transmission: Th350
Axle/Gears: 4.10
Got any pictures of your car's interior/exterior?
Old 03-03-2014, 01:38 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: Strange 12 bolt 3.42
Old 03-03-2014, 08:16 PM
mw66nova's Avatar
Engine: 7.0L
I found out the year split. The 82-87 had the c - channel crash bar and the 88-92 had the tubular bar.
Old 03-08-2014, 12:03 AM
tvc 15's Avatar
Car: 88 rs
Engine: ls1
Transmission: t56
Build is in Fabrication under "ls1 roadracer project"
Attached Thumbnails Pictures of door panels in street/strip or racecars?-done-006.jpg   Pictures of door panels in street/strip or racecars?-done-008.jpg   Pictures of door panels in street/strip or racecars?-done-012.jpg
Old 03-21-2014, 09:26 PM
kthxbai's Avatar
Car: 1985 Z28
Axle/Gears: fourth gen 3.42
Spent the last few afternoons putting together some door panels.
Steven
Old 03-21-2014, 10:08 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
I like the door strap idea.
Old 07-19-2014, 11:36 PM
kthxbai's Avatar
Car: 1985 Z28
Went and finished them off with black fabric and spray adhesive, as well as a slim felt backing to stop any rattles.
Old 07-20-2014, 08:21 AM
mw66nova's Avatar
Engine: 7.0L
That turned out great!
Old 08-06-2014, 08:57 AM
Wife'sCar's Avatar
Car: 91 Camaro RS T-Top
Engine: 5.0 Tbi
Going to be making my own door panels prolly this weekend, not weight saving or anything just tired of my tore up cardboard panels and not paying the crazy prices for good condition panels. I've got 26 gauge galvanized steel, it was free and I'm not worried about weight savings in my wife's daily driver. I've got my plans set for making them and how to attach them, for those using screws/bolts through the front of the panel, what size/length/thread are you using. I've thought about tacking some nuts on the door and using allen head bolts to match the lock/handle screws.
Old 08-06-2014, 08:48 PM
kthxbai's Avatar
Car: 1985 Z28
I used plastic screw/push type rivets, I think they are 3/8" or 7/16"? Used 12 or so of them in all the stock locations around the perimeter, looks clean and is very easy to remove and replace.
~Steven
Old 08-07-2014, 04:33 PM
Wife'sCar's Avatar
Engine: 5.0 Tbi
One down!!!
Need to buy more clips tomorrow, ran out, need 13, only had 9.
Old 08-07-2014, 05:49 PM
kthxbai's Avatar
Car: 1985 Z28
Lookin good
Old 08-07-2014, 07:31 PM
Wife'sCar's Avatar
Engine: 5.0 Tbi
I peeled the fabric from the stock cardboard panel, traced the cardboard panel on a sheet of steel, cut that out, glued the cardboard to the back of the new metal panel so the panel wouldn't rattle against the door, then laid that on a sheet of auto carpet, traced it a little bigger, glued that and wrapped the edges and drilled holes in the panel in the stock clip locations and used the style clips suggested.
I'm positive its heavier than the original panel but it looks and feels so much better to have a solid panel and not the deteriorated and falling off old panel.
Old 01-08-2015, 07:47 AM
billybob6110's Avatar
Car: 1984 chevy camaro
Engine: 355
Transmission: turbo 350 2800 stall
Axle/Gears: 3:73 detroit locker posi
Before Cutting out:
After Cutting out:
where did you find these straps at?
Old 01-08-2015, 08:21 AM
mw66nova's Avatar
Engine: 7.0L
i don't know about those ones, but my cousin and fellow TGO member sells these:
http://www.ebay.com/itm/Rally-Racing-Custom-Door-Pull-Strap-23-Colors/141256248258?_trksid=p2050601.c100272.m3467&_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D20140813112422%26meid%3D7521f9383c0c49c29daf200bd78bf69f%26pid%3D100272%26prg%3D20140813112422%26rk%3D1%26rkt%3D4%26sd%3D141256248258%26clkid%3D3215215896449221177&_qi=RTM1963929
Old 02-20-2015, 07:48 AM
z28venezuela's Avatar
Car: Black Z28 1983
Transmission: I'm Swapping to Manual
Maybe you're going to need this.
https://www.thirdgen.org/forums/fabr...-template.html
Frozer!!!
01-19-2024 04:55 PM
1992 Trans Am
05-10-2023 07:19 PM
Vintageracer
01-10-2020 05:33 PM
IROCZDAVE (88-L98)
10-06-2016 09:08 AM
Out-Cast
08-23-2015 06:33 AM
Quick Reply: Pictures of door panels in street/strip or racecars?
