Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
double adjustable front shocks
Old Sep 5, 2014 | 07:56 PM
heavy_chevy29's Avatar
Car: 84 camaro Z28
Engine: 434sbc
Transmission: powerglide
Axle/Gears: moser 9" with 411 posi
im at the point where id probably benefit front a good set of double adjustable front shocks. ive run a best of 9.54 @ 141mph(hoping for really high 8s this year). ive been looking into a good set of double adjustable front shocks. ive been running lakewood 90/10s with racecraft coil over kit. are santhuffs the best or is there something more affordable out there any help would be great.
Old Sep 5, 2014 | 09:05 PM
DIGGLER's Avatar
Re: double adjustable front shocks
as expensive as they are, santhuffs still arent the most expensive. lol
but they are fantastic. the main thing for me is simply controlling the extension slow enough to keep the front down while still being able to use your available travel. being able to do that means you can extend the amount of time you are transferring weight. with a shock thats too fast you are forced to use limiters, and your front end can only help with weight transfer briefly and might only have 3" of extension available.
Old Sep 9, 2014 | 05:11 PM
86iroc2try's Avatar
Car: 84 camaro
Engine: HRE 355
Transmission: th350
Axle/Gears: 4.56
I only run high 9s but I switched from 90/10s to qa1 dbl adj coilovers.
The front end is much tighter and less bouncy touching down. Work fine for me...almost bought santuffs but couldn't afford the extra cost quite yet.
customblackbird
Aug 15, 2021 10:16 PM
LT1Formula
Nov 16, 2015 01:13 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Dialed_In
Aug 20, 2015 01:45 PM
