Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
New solid cam installed
Old Nov 8, 2016 | 09:48 AM
  #151
skinny z's Avatar
Re: New solid cam installed
Digging through my books looking for primary tube calculations and I found:
Based on your exhaust port flow at max lift; 160 CFM @ .500"
Purpose of the vehicle; drag racing where maximum RPM is seen most of the time (lowest RPM is 75-80% of the max)
A 1 5/8" I.D. header is said to be able to do the job.
The variable here is you've added nitrous which typically calls for more exhaust everything.
FWIW. There may be gain on the exhaust side with a 1.6 ratio rocker if performance on N20 is more important than not. Same might be said for a larger primary tube but the text books say 1 5/8".
Old Nov 19, 2016 | 09:44 PM
  #152
WickedBowtie's Avatar
Car: 1989 Camaro RS
Engine: 383
Transmission: TH400
Axle/Gears: 9 inch, 35 spline drag spool,4.56
Cool, thanks man.
Old Nov 19, 2016 | 10:31 PM
  #153
rb85TA's Avatar
Car: BUILDING 1985 HARD TOP T/A
Engine: sbc
Transmission: stick
Axle/Gears: GM
I would call your head Porter, see what he thinks. Not, up to date on your build/spec's so any recommendations wouldn't be relative to it.
Old Dec 5, 2016 | 08:46 PM
  #154
Car: 1989 Camaro RS
Engine: 383
Transmission: TH400
Got rack installed
V8Rumble
Mar 15, 2008 10:46 PM
tpi_master
Feb 18, 2002 08:54 AM
