Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
question about bolt pattern size...
Old Dec 28, 2001 | 07:54 AM
zboss86's Avatar
What's the size of the bolt pattern on a thirdgen camaro...
also what is the backspacing?
While I'm at it, if I wanted to stick a 10 inch rim under my car would I need a rim with a different backspacing?
What does the back spacing need to be for a front skinney?
just ignorance asking here...
Old Dec 28, 2001 | 08:17 AM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
The bolt pattern is 5X4.75", but the backspacing is different between the front and rear wheels with 16" rims, same b/s for 15" rims. Yes, you'd need different backspacing for a 10" rim, but I don't know what it'd be off-hand. Most front skinnies (from 3 1/2" to 6" wide) only have 1 backspacing listed for each size, at least from what I've seen in the Weld wheels like the Draglites and Pro Stars.
84z96L31vortec
Aug 20, 2017 12:16 AM
beastin91rs
Oct 9, 2015 07:38 AM
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
redmaroz
Aug 16, 2015 11:40 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
