Spohn Spherical Rod End Sway Bar End Links
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
What’s the groups thoughts on the Spohn Spherical Rod end Sway Bar End Links in regards to auto cross or road racing and over all street driving? Beneficial or just snake oil?
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Re: Spohn Spherical Rod End Sway Bar End Links
They look cool, but do you really need them? What would be the benefit? I know a lot of modern cars have rod-end bearing end links.
I made my own for a Ford product (with leaf springs) that has an after market rear sway-bar, but the reason I did is because of a weird angle that wasn't working well with the standard type links. Not sure of the benefit on a thirdgen but would be interesting to hear from an expert...
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Back when I still had stock suspension under my car, I had adjustable LCA with the rod ends. Main advantage was the adjustability. The rod ends just gave more freedom of movement to prevent any binding. A street car can get away just fine with the rubber or poly bushing but a competition car should have something a little better.
My90Iroc
Mar 26, 2003 10:52 AM
tazmision89
Nov 1, 2002 07:09 PM
