Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
What should I run in the 1/4?
Old Mar 24, 2002 | 01:22 AM
SMKNGTA's Avatar
Car: 1989 GTA
Axle/Gears: 9bolt 3.27s
My specs are in my sig, I'm thinking low 13's with traction and maybe high 12's with headers, no cats and the right conditions. What do you think?
Old Mar 24, 2002 | 09:40 AM
jamesbern's Avatar
Depends on if you are using slicks or not. How much does your car weigh?
Old Mar 24, 2002 | 10:46 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Read the message "take it to the track". If you want a guess then assuming the car and driver are around 3500 pounds and you quote having 257 RWHP, I say it'll run 13.9
Old Mar 24, 2002 | 03:36 PM
SMKNGTA's Avatar
Car: 1989 GTA
I will not be running slicks but I can drive the car good and the car is about 3500lb's with me. I think it should be faster than 13.9 because I raced a my friends 2000 LS1 Trans Am Auto with 3.73's, cold air intake, Hypertech programer, MAF, and Free mods. We were dead even at 80 mph and than we shut down, I know he would have pulled away if we kept going because the LS1 breaths much better than the TPI, so I know my car should run atleast low 13's as is. Stock LS1's have broken into the 12's on stock tires.
Old Mar 24, 2002 | 04:17 PM
AlkyIROC's Avatar
Car: 87 IROC L98
If you think it will run quicker than 13.9 then either the car is much lighter or you have more than 257 RWHP.
Old Mar 25, 2002 | 07:16 PM
jamesbern's Avatar
I have to agree with Stephen this once, you will probably only get a high 13 on street tires. My car can run right with the new Camaro's on the street too and I could only get a low 14 at the track. The LS1 Camaro's where I am at only get high 13's on street tires even with experienced drivers (guys with other cars that pull of 10's and 11's), with average drivers low 14's like mine. With all of that torque and no slicks you will have a very tough time getting traction, my 60 ft. times were in the 2.5-2.6 area all traction related. The good news is that with slicks you should pick up about .6 in the quarter. Good luck!!
Old Mar 25, 2002 | 09:41 PM
SMKNGTA's Avatar
Car: 1989 GTA
I understand what you guys are saying about traction, it's a hell of a car to launch. How well do BFG or Nitto drag radials hold up. Does any one know if the G-tech pro is as accurate as they say? Thank you for your relpys.
Old Mar 25, 2002 | 09:47 PM
fattie92's Avatar
my gtech says my stock 84 ta (carbed 305) rran a best of 16.7 at around 89mph...thats pretty accurate...the time is close as hell,,, but the MPH is kinda high..
Old Mar 25, 2002 | 10:30 PM
SMKNGTA's Avatar
Car: 1989 GTA
Does the G-tech tell you 60ft and 1/8mi times?
Old Mar 26, 2002 | 07:36 AM
fattie92's Avatar
for all your GTECH needs go here GTECHPRO
eightsixseven
Dec 16, 2024 01:50 PM
evilstuie
Jan 9, 2020 08:29 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Fast355
Dec 2, 2016 06:33 PM
perZ
Aug 21, 2015 05:51 PM
