87 Trans Am project for sale in Salem, OR
Car: 87 Trans am
Transmission: built 700R4
Axle/Gears: BW 9 bolt posi w/ disc
Would like to sell this car locally rather than dealing with shipping it anywhere.
Here is the rundown on the car and the parts that are on it.
Bought it in August of 09 from a friend of a friend who i met through another car forum. The guy i met on the forum put all these parts on it, all ive done is start body work and put new tires on it and the disc brake rear end. Car currently has about 91,000miles on the chassis. There are only about 15k on the motor. The transmission has a shift kit and VB upgrade although im unsure of what kind. Likely needs a trans fluid flush as im not sure of the last time it was done. Shifts just fine, cruises nicely on the freeway. Only thing i have noticed is that when your on the throttle hard it doesnt like the 3rd gear shift, likes to hit the rev limiter before it shifts.
The good:
5.7 liter 350 Tuned Port Injection swap (original 305 car)
700-R4 auto 4-speed
9-bolt borg warner rear end with 2.92gears(i think)
WS6 performance suspension package
ZZ4 aluminum heads - 58cc chambers, D-port exhaust
ZZ4 camshaft - Duration Lift: 208/221@ 0.050" Lift: .474"int/.510"ex Lobe Separation: 112
Edelbrock ceramic coated 1 5/8 headers
Edelbrock ceramic coated 3in Y-pipe
3in off-road pipe (replaces cat)
3in intermediate pipe
3in cut-out
Flowmaster 80s
TB bypass
Custom CAI w/K&N cone
Custom chip
Well's hi-flo MAF
Ported Plenum
160* thermostat
185* fan switch
MSD Super Conductor 8.5mm wires
LT1 fuel pump
24# Ford Blue Top fuel injectors
MSD GM Blaster Coil
New GM Distributor
1.5 rockers
LT4 valve springs
Crane Adjustable Fuel Pressure Regulator
Zinc plated slotted & cross drilled rotors
Wilwood adjustible proportioning valve
17x9 ROH Snyper rims
NEW Federal SS595 tires
255/40/R17 in front; 275/40/R17 in back
4th gen front seats
tripple pillar pod (not installed)
new weatherstrips all around
absolutly NO RUST
Originally a california car, only been up here in the PNW since april of this year.
the bad:
-Has an exhaust leak coming from the passenger side exhaust manifold gasket
-Center console is seperating
-Needs paint and a little more body work
-Needs a disc brake master cylinder
-Water temp gauge in the dash doesnt work, ill include an autometer gauge with the car to go in the pillar pod.
-Does not have the a/c compressor or lines from the dryer to the compressor. The lines are at my parents house in southern california where i bought the car.
im located in Silverton, OR (10miles east of Salem)
Putting it up for $3200 OBO. Im flexible on price but figured i would put up a starting point.
I wouldnt hesitate driving this car anywhere however, i do not have the time to deliver it outside of 50 miles.
please feel free to reply on here or email me at bluexrunner@gmail.com
dont be affraid to make an offer guys! Id take a rolling chassis 3rd gen trade plus cash!
http://s193.photobucket.com/albums/z...t=S7300908.flv
The good:
700-R4 auto 4-speed
3in cut-out
Flowmaster 80s
TB bypass
Custom chip
Well's hi-flo MAF
Ported Plenum
160* thermostat
185* fan switch
LT1 fuel pump
MSD GM Blaster Coil
New GM Distributor
1.5 rockers
LT4 valve springs
4th gen front seats
absolutly NO RUST
the bad:
Car: 87 Trans am
Re: 87 Trans Am project for sale in Salem, OR
no offers guys? i need to sell this car to help pay for things around the house and my new project.
colton_carlson
Mar 8, 2019 12:21 PM
ambainb
Apr 25, 2016 09:21 PM
