Pacific Northwest Region Regional discussion board for WA, OR, ID, and BC.
New owner of 92 Trans Am in Oregon
Old Jun 13, 2011 | 12:57 PM
Firebird_92's Avatar
Car: 92 Trans Am
Engine: LB9 305 TPI
Axle/Gears: 2.73 Posi
I just traded a Para FAL battle rifle for a 92 Trans Am with a 5.0 MFI and 700r4.
The car is in pretty good shape but definitely needs a new paint job. It has modern aftermarket aluminum wheels and newer BFG radial tires on it
I just picked it up last Friday and will be giving it a full tune-up since it sat since last Fall.
Where is the best place to find replacement Trans Am tail lights without breaking the bank?
Thanks,
Doug
Old Jun 13, 2011 | 05:37 PM
AmorgetRS's Avatar
Re: New owner of 92 Trans Am in Oregon
Good luck in finding the 91/92 Trans Am/TA tail lights... they are very rare and a nice set sells for 400+ from what I have seen.
Welcome to the site!
Old Jul 21, 2011 | 06:51 PM
Car: 92 Trans Am
Engine: LB9 305 TPI
After doing some research today, my Trans Am might be a GTA model. I'll know more when I get home to check the SPI label.
Old Jul 21, 2011 | 09:05 PM
AmorgetRS's Avatar
If you have the SPID look for Y84, that is the only way to be sure it is a GTA
Old Jul 26, 2011 | 11:23 AM
Car: 92 Trans Am
Engine: LB9 305 TPI
Well I ran my VIN on comp nine and it is only a TA but that is fine with me since '92 was a short production year with only 969 Trans Ams made.
Here is the list of options my TA came out with;
Here is what the comp nine website brought up from my VIN;
Vehicle: FIREBIRD 2 DR
Year: 1992
Build Date: 1992-07-01
Found 22,334 vehicles matching your year and model in our database.
RPO Description Matches
UB3 CLUSTER,INSTRUMENT(OIL,COOLANT TEMPERATURE,VOLTMETER,TACHOMETER,TRIP ODOMETER) GA(UB3)
CLUSTER,INSTRUMENT(OIL,COOLANT TEMPERATURE,VOLTMETER,TACHOMETER,TRIP ODOMETER)(USED WITH BERETTA GT PKG Z21) GA(UB3)
22,334
UM6 RADIO,AM/FM STEREO,CASSETTE,ETR,INCLUDES CLOCK STEREO CASSETTE(UM6)
9,061
UQ1 RADIO,PROVISIONS FOR STEREO STEREO RDO PR0VISIONS(UQ1)
22,334
U62 SPEAKER SYSTEM,4,DUAL COAX FRONT,DUAL COAX PACKAGE SHELF 4 SPKR SYS(U62)
22,334
VAN PLANT CODE VAN NUYS, CA, CPC VAN NUYS,CA PLANT CODE(VAN)
22,334
VK3 LICENSE PLATE,FRONT MOUNTING PACKAGE FRT LIC PLT MTG PKG(VK3)
16,875
VQ5 Unk. 45
VX5 FLEET PROGRAM - CASH ALLOWANCE
113
V73 VEHICLE STATEMENT - US/CANADA US/CANADA VEHICLE STATEMENT(V73)
20,779
WS4 TRANS AM OPTION TRANS AM(WS4)
TRANS AM(MERCHANDISING OPTION)(2FS87 + WS4 = 2FW87) TRANS AM(WS4)
1,056
Y83 TRANS AM PACKAGE(MERCHANDISING OPTION) TRANS AM(Y83)
702
Y99 HANDLING PACKAGE HANDLING PKG(Y99)
HANDLING PACKAGE(USED WITH SE Z7M) HANDLING PKG(Y99)
257
ZV1 STATEMENT OF ORIGIN - MANUFACTURE
1,671
1SC PACKAGE-OPTION 03 (1SC)
18,423
1SZ PACKAGE OPTION- (1SZ)
21,331
18Q MOLDING COLOR,DK GREEN GRAY METALLIC (18Q)
988
18U EXTERIOR COLOR,PRIMARY (18U)
EXTERIOR COLOR,PRIMARY,DK GREEN GRAY METALLIC (18U)
992
41P WHEEL COLOR,BLACK (41P)
881
6ZW SPRING COMPTR SELECT FRT LH SUSP(6ZW)
1,161
64C TRIM COMBINATION CLOTH, LT BEIGE (64C)
5,980
64I INTERIOR TRIM,LIGHT BEIGE (64I)
6,057
649 SEAT BELT COLOR,LIGHT BEIGE (649)
6,057
7ZW
SPRING COMPTR SELECT FRT RH SUSP(7ZW)
1,161
8NL SPRING-COMPTR SELECT RR LH SUSP(8NL)
1,899
9NL SPRING-COMPTR SELECT RR RH SUSP(9NL)
1,899
AAA STANDARD EQUIPMENT
21,257
AH3 ADJUSTER,SEAT,4-WAY MANUAL,DRIVER 4-WAY MAN D/SEAT ADJR(AH3)
8,697
AJ3 RESTRAINT SYSTEM,FRONT SEAT INFLATABLE DRIVER SI INFL RST SYS(AJ3)
22,334
AR9 SEAT,FRONT BUCKET,DRIVER,PASSENGER,MANUAL RECLINING(EUROPEAN STYLE) MAN RECL FRT BKT ST,DELUXE(AR9)
21,980
AU3 LOCK,SIDE DOOR,ELECTRIC ELEC S/D LK(AU3)
20,734
A31 WINDOW,ELECTRIC OPERATED,SIDE ELEC SI WDO(A31)
20,734
A90 LOCK,REAR COMPARTMENT LID,REMOTE CONTROL,ELECTRIC RELEASE ELEC REL LID LK(A90)
18,825
BC8 ORNAMENTATION,INTERIOR,FRONT DOOR MAP POCKET RH AND LH DR MAP PKT(BC8)
20,734
B84 BLACK BODY SIDE MOLDING BODY SI MLDG(B84)
ORNAMENTATION,EXTERIOR,BODY SIDE MOLDING BODY SI MLDG(B84)
ORNAMENTATION,EXTERIOR,BODY SIDE MOLDING(USED WITH TROFEO SPORT COUPE WL3) BODY SI MLDG(B84)
22,096
C49 DEFOGGER,REAR WINDOW,ELECTRIC ELEC RR WDO DEFG(C49)
15,872
C60 AIR CONDITIONER,FRONT,MANUAL CONTROLS A/C MAN CONT(C60)
22,220
DC4 MIRROR,INSIDE,REARVIEW TILT,DUAL READING LAMP I/S DUAL READING LP RR VIEW MIR(DC4)
22,062
DG7 MIRROR,OUTSIDE,RH & LH REMOTE CONTROL,ELECTRIC(PAINTED) O/S ELEC R/CON PAINTED MIR(DG7)
17,357
D3W GEAR-SPEEDO DRIVEN (25513044) (D3W)
6,153
D8N SENSOR VEH SPD (10456088) (D8N)
19,151
D81 SPOILER,REAR,AERO WING RR AERO WING SPLR(D81)
3,122
E5Z ADAPTER - SPEEDO - DELETE
22,334
E9Z KEY - SPEEDO - DELETE
22,334
FLT SALES PROCESSING - OPTION
1,564
F41 SUSPENSION,FIRM RIDE HANDLING,FRONT AND REAR FIRM RIDE & HANDLING SUSP(F41)
SUSPENSION,FIRM RIDE HANDLING,FRONT AND REAR(USED W/TOURING PKG WF1) FIRM RIDE & HANDLING SUSP(F41)
SUSPENSION,FIRM RIDE HANDLING,FRONT AND REAR(USED WITH GRAN TOURING PKG Y56) FIRM RIDE & HANDLING SUSP(F41)
257
GU2 AXLE,REAR,2.73 RATIO 2.73R(GU2)
6,748
G80 AXLE,REAR,POSITRACTION,LIMITED SLIP POSITRACTION L/SLIP R/AXL(G80)
1,782
IPC TRIM,INTERIOR DESIGN (IPC)
21,980
J41 BRAKE SYSTEM,POWER,FRONT DISC,REAR DRUM(CAST IRON) CAST IRON FRT DISC/RR DRUM BRK SYS(J41)
21,243
K34 CRUISE CONTROL,AUTOMATIC,ELECTRONIC CRCONT(K34)
14,670
K68 GENERATOR,105 AMPERE 105 AMP(K68)
8,465
LB9 ENGINE,5.0L(5.0F),V8 EFI CAR ONLY 5.0F(LB9)
750
MD8 TRANSMISSION,AUTOMATIC 4-SPEED(THM700R4/4L60) 4-SPD A/TRANS(MD8)
19,979
MX0 TRANSMISSION,AUTOMATIC,OVERDRIVE(MERCHANDISING OPTION) A/TRANS PROVISIONS(MX0)
19,979
NA5 EMISSION SYSTEM,FEDERAL REQUIREMENTS FEDERAL EMIS(NA5)
20,205
NP5 STEERING WHEEL,LEATHER WRAPPED LEATHER WRAPPED STRG WHL(NP5)
STEERING WHEEL,LEATHER WRAPPED(USED WITH GRAN TOURING PKG Y56) (NP5)
1,056
N65 WHEEL AND TIRE,SPACE SAVER SPARE,STEEL STEEL SPACE SAVER SPA(N65)
691
PW7 WHEEL,16X8,STYLED(ALUMINUM)(SUPERLIGHT) STYLED AL WHL(PW7)
1,446
QPE TIRE ALL- P215/60R16/N BL R/PE ST TL AL2 TIRE(QPE)
TIRE ALL- P215/60R16/N BL R/PE ST TL AL2(USED WITH GRAN TOURING PKG Y56) TIRE(QPE)
257
R6U CONTROL - SALES ITEM NO. 20
2,220
T93 LAMP,TAIL AND STOP(SPECIAL) SPECIAL TAIL & S/LP(T93)
LAMP,TAIL AND STOP(SPECIAL)(USED WITH TOURING YP6) SPECIAL TAIL & S/LP(T93)
684
T96 LAMP,FRONT FOG FRT FOG LP(T96)
LAMP,FRONT FOG(EXPORT) FRT FOG LP(T96)
LAMP,FRONT FOG(USED WITH BERETTA GTZ Z04) FRT FOG LP(T96)
LAMP,FRONT FOG(USED WITH TOURING YP5) FRT FOG LP(T96)
LAMP,FRONT FOG(USED WITH TOURING YP6) FRT FOG LP(T96)
LAMP,FRONT FOG(USED WITH TROFEO WL3) FRT FOG LP(T96)
18,323
Rarity...
There are 1 1992 FIREBIRD 2 DR vehicles (0.004%) matching your exact options list. There are 5 (0.022%) with at least as many options.
Old Jul 26, 2011 | 12:37 PM
AmorgetRS's Avatar
Nice. Don't expect a screamer, no WS6 option and 305 AT w/ 2.73 rear end. Great highway cruiser, though. My 91 GTA was setup that way.
eightsixseven
Dec 16, 2024 01:50 PM
theshackle
Aug 23, 2015 03:49 PM
theurge
Aug 21, 2015 12:46 PM
3rdgenparts
Aug 6, 2015 09:03 AM
