Pacific Northwest Region Regional discussion board for WA, OR, ID, and BC.
Anyone in the Tri Citys run a EBL?
Old Jan 21, 2014 | 10:58 PM
fox_305's Avatar
Car: 91 Z28 camaro
Transmission: T 5
Axle/Gears: yukon duragrip 4.11
Anyone in the tri cities WA have a EBL ecm? I am thinking of getting one when the weather gets better but I could use a little help tuning. I have never tuned before and am a little intimidated by it. I have done lots of reading here and on dynamicefi's website and its still a little fuzzy, so any help would be appreciated. Thanks
Old Jan 22, 2014 | 07:47 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: Anyone in the Tri Citys run a EBL?
You might want to look on the classified section on this forum.
Old Jan 22, 2014 | 07:04 PM
fox_305's Avatar
Car: 91 Z28 camaro
Transmission: T 5
You misunderstood me, I am looking for help using an EBL ecu and tuning it.
Old Jan 23, 2014 | 02:06 AM
gregl316's Avatar
Car: 91 RS convertible
Engine: 330 hp vortec 350. TBI
Transmission: 5 Speed
Axle/Gears: 3.73 Moiser 12 bolt/Wilwood disc's
Well dude I am in the Portland area. In have been trying to get it dialed in for over a year. I have not found anyone arround here that has even heard about them. I am going to have it tuned by someone else that is if I can find someone. My tune is going no where. RBob has really been trying to help but it isn't helping. I jus don't get it. If you find someone I am willing to do the drive.
I am just alittle flustrated.
Old Jan 23, 2014 | 08:08 PM
fox_305's Avatar
Car: 91 Z28 camaro
Transmission: T 5
greg what system do you have? EBL or EBL P4? What kind of problems are you running into? Is you car not drivable, or is it just not getting the results you want?
Old Jan 23, 2014 | 09:46 PM
gregl316's Avatar
I have an EBL never heard of the other. No it works I just don't know what to do. You can latterly adj every thing.
Old Jan 24, 2014 | 12:31 AM
fox_305's Avatar
Car: 91 Z28 camaro
Transmission: T 5
So are you data logging and then performing a VE learn? Also are you using a WB O2 sensor in junction with the ebl system? The EBL P4 is a newer version of the classic ebl with some software upgrades and a usb port instead of a serial port.
Old Jan 25, 2014 | 06:07 AM
gregl316's Avatar
I do VE learns and then flash. I do data logs too but not sure why. I have a narrown band. My EBL is only a 1 and 1/2. old. I still haven't gotten my car running rite yet. I haven't logged to many mikles though. I just went from a straight adj fpr to a vac fpr and it seem to have really helped.
Old Jan 25, 2014 | 10:42 AM
fox_305's Avatar
Car: 91 Z28 camaro
Transmission: T 5
A data log is just a recording information of what the cars ecm is seeing and sending out to the ignition and injectors and other controlled functions of the ecm. You can use a log to see what the car was doing when it did something you didn't like (ex stumble).
With a narrow band you can only ve learn the spark tables but with a wb o2 it will adjust the fuel tables as well, which might make it easier to get your car running better.
I bought one so I could see what my af ratios are, a wide band O2 is a great tuning tool for any motor carb or efi.
Old Jan 25, 2014 | 09:13 PM
gregl316's Avatar
I agree with you but how do you install one? Where do you hook it up? Alot of people have told me that.
Old Jan 25, 2014 | 10:58 PM
fox_305's Avatar
Car: 91 Z28 camaro
Transmission: T 5
Well to start off I do not have my ebl yet, as I am waiting for nicer weather/ cash to get better. A good digital WB O2 will run you $150-$200 and are super easy to install. I have this one
Amazon Amazon
You weld in a o2 bung, hock up a power/ground wires and then run the signal wire to the ebl
Here is the write up bob did on his web site of how to run date inputs to the ebl and set the parameter in the software.
http://www.dynamicefi.com/ADC_Connect.php
Hope this helps.
Old Jan 26, 2014 | 10:28 PM
gregl316's Avatar
I am tired of throwing money at this damn car to get it to run rite. I was told by everyone that the EBL is the best thing and the tuning will be better. Rite now I wish I would have kept the stock set up and had a chip burnt and been done with it. My build is a common build I figure some one would of allready had a BIN that is pretty close if not dead on.
I wrote Bob and sent him my recent data log to see if he could make heads or tail of it and he hasn't gotten back to me yet. That is the one good thing he seemd to be there for you.
I think I am going to a profession dyno tuner and see if they can help. They are just real busy and at least arround here they have never heard of an EBL.
You seem to know what you are dealing with I hope it works for you.
Old Feb 27, 2014 | 01:26 AM
gregl316's Avatar
If you want my EBL I'll sell it to you. I went back to the stock computer and had a chip burnt on a dyno. Now I'm done period. No more farting arround.
Old Mar 1, 2014 | 10:03 PM
fox_305's Avatar
Car: 91 Z28 camaro
Transmission: T 5
What one do you have? (regular ebl or a ebl p4) how much do you want for it?
Old Mar 2, 2014 | 01:11 PM
gregl316's Avatar
I don't know? Whats the difference? I want arround $300 for it and I'll pick up shipping.
Old Mar 6, 2014 | 12:05 AM
fox_305's Avatar
Car: 91 Z28 camaro
Transmission: T 5
I just need some info on it to try and figure out what model you have. Its like you are trying to sell me a and all you tell me is its a third gen. The ebl is different for tpi and tbi cars plus there is a new model out. I would like to know when you bought it and if you could plug a usb cable into it. Thanks
ps I would just come and get it in person my wife would love an excuse to go to Portland haha
Old Mar 8, 2014 | 09:24 AM
gregl316's Avatar
Sorry dude
I bought it for my 91 with a TBI
It is about 2 year old
Yes I have the adapter that goes to your USB drive
It has a sticker on it that says
"Dynamic EFI's EBL Flash with what's up Display"
Email me at gregl316@hotmail.com
eightsixseven
Dec 16, 2024 01:50 PM
MustangBeater20
Oct 29, 2022 09:20 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
lakeffect2
Aug 23, 2015 08:44 AM
zeitghaist
Aug 18, 2015 07:33 AM
