Pacific Northwest Region Regional discussion board for WA, OR, ID, and BC.
OK I need help on my launch and some other things
Old Jul 20, 2001 | 12:06 PM
82Zee28's Avatar
Actually, I have two, kinda related questions:
Question #1. What is the best way to start a burnout in my 82 Z28? I have a 305 auto with Posi. Is it better to start in first, RPM's up to 5K, then to second, RPM's to 5k, then to drive and slowly release brake? Or, just start in drive? I tried the gear thing on the 4th and it didn't seem like I had the torque needed.
Question #2. When racing someone from the line, should I drop the gears for better traction or just leave her in drive?
OK, I guess I have a 3rd question: If going about 35 MPH and some loser in a VW Jetta (or whatever it was)cuts me off and I want to romp on him, is it going to kill my tranny if I throw her into 2nd or should I just lay on the gas? My carb is acting up (no, I'm not going EFI)so my response time kind sucks right now but I want to know what the best way to handle this is without trashing on my car.
Thanks.
This message has been brought to you in part by Metallica
Old Jul 20, 2001 | 01:14 PM
PonchoTA's Avatar
Out of all the "trial runs" I have made and the racers for the magazines, the best way to launch the car for racing, is to just put it in D (not OD! Evidently different fluid flows within the tranny), apply the brakes hard, rev the engine to about 1500 rpm, and when you are ready to go (last yellow light) release the brakes, and feather the gas (to keep traction) until it's floored! I've always been able to force the shift around 4500rpm by a slight lift of the accelerator and punching it again. That will keep you in the torque/power curve of the engine, but still prevent loss of traction. From there on, just hold on and enjoy the ride watching the scenery pass by!!
For just doing a burn out, DON'T put it in Neutral, rev, then drop in gear!! That will mess it up fast!! You should be able to light the tires with the braking technique easily! You shouldn't even have to rev very high, until the wheels start spinning, then you want to get lots of heat in the tires! Just keep an eye on the yellow/redline on the tach! It will go high, fast! Don't want to blow the engine just doing a burnout, do you??!!!
Hope this helps!!
Paul
Old Jul 20, 2001 | 01:22 PM
82Zee28's Avatar
<font face="Verdana, Arial" size="2">Originally posted by PonchoTA:
For just doing a burn out, DON'T put it in Neutral, rev, then drop in gear!! That will mess it up fast!! You should be able to light the tires with the braking technique easily! You shouldn't even have to rev very high, until the wheels start spinning, then you want to get lots of heat in the tires! </font>
What about if I start out in 1st? Or is Drive better? drive works fine for me, but someone recommended I start in 1st, then build up but I couldn't do it.
<font face="Verdana, Arial" size="2">Don't want to blow the engine just doing a burnout, do you??!!!
</font>
No. That's why I'm asking. I would be in big trouble with the hubby if I did that. Then again, all the more reason for a 350. But still, I don't like to trash on my car if I don't have to.
Old Jul 20, 2001 | 01:31 PM
Demon Z28's Avatar
Car: 2001 Camaro SS
Engine: Almighty LS1
Summer you do good burnouts for now as it is... your tires just have a lot of bite to them compared to what everyone else has (like Lance's tires n stuff hehehe)
Old Jul 20, 2001 | 01:36 PM
82Zee28's Avatar
<font face="Verdana, Arial" size="2">Originally posted by 82Zee28:
OK, I guess I have a 3rd question: If going about 35 MPH and some loser in a VW Jetta (or whatever it was)cuts me off and I want to romp on him, is it going to kill my tranny if I throw her into 2nd or should I just lay on the gas? My carb is acting up (no, I'm not going EFI)so my response time kind sucks right now but I want to know what the best way to handle this is without trashing on my car.</font>
Then what about this? I'm not a sore loser, it's the thrill of the race that gets me going. But I'd like to make sure I'm getting what I can from my car. Don't want to lose to a Cabriolet if I don't have to.
Old Jul 20, 2001 | 01:40 PM
Demon Z28's Avatar
Car: 2001 Camaro SS
just put that other carb on there and call it good, hehehe if your carb is being a piece of shyt right now I wouldn't risk it...
Does your engine still need a tune up??
Old Jul 20, 2001 | 01:49 PM
82Zee28's Avatar
Dude, I cannot put that Edelbrock 750 cfm carb on my 305.
Doesn't need the tune up. I did that when it needed it. Cap/rotor, plugs, wires, etc.
It's the stock QJ. And it sucks.
Old Jul 20, 2001 | 01:51 PM
Demon Z28's Avatar
Car: 2001 Camaro SS
Oh... I thought you had a smaller one... hrm
!? I dunno
Old Jul 20, 2001 | 01:59 PM
Blue502's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Demon Z28:
(like Lance's tires n stuff hehehe)</font>
Hey now, remember I now have wide 16" tires on there instead of the narrow 15"ers and they are Z rated to boot with a sticky 145 treadwear rating. There may not be a whole lot of tread there, but they are still legal. Of course I do have an open rearend...
Summer, you could always get a V6 Crista's gonna kick your Z butt with her birdy, hehehe j/k
Old Jul 20, 2001 | 02:04 PM
Demon Z28's Avatar
Car: 2001 Camaro SS
your tires are balder than a baboons ****, lance
Old Jul 20, 2001 | 02:06 PM
Blue502's Avatar
You should know
Old Jul 20, 2001 | 02:18 PM
82Zee28's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Blue502:
Summer, you could always get a V6 </font>
Hahahahahahahaaa!!! Yeah, right.
<font face="Verdana, Arial" size="2"> Crista's gonna kick your Z butt with her birdy
</font>
Not if I can help it! I know I've got her until she learns to drive that thing. TGFM's!!
It will be fun to race her, though. Nothing wrong with a bit of Cascade Crew Sibling Rivalry.
Old Jul 20, 2001 | 02:19 PM
Demon Z28's Avatar
Car: 2001 Camaro SS
hey its not my fault theres occasionally nothing better on TV than the damned animal channel!!
The Crocodile Hunter kicks *** !!!
"Rawght, Now! I'ma stick my thumb up his bum... theese should really pyss 'im off!!"
Old Jul 20, 2001 | 02:20 PM
82Zee28's Avatar
your tires are balder than a baboons ****, lance </font>
But they smell a heck of a lot better!
Old Jul 20, 2001 | 02:21 PM
82Zee28's Avatar
"Rawght, Now! I'ma stick my thumb up his bum... theese should really pyss 'im off!!"</font>
So that's where you got that idea?!?!
Old Jul 20, 2001 | 02:25 PM
Demon Z28's Avatar
Car: 2001 Camaro SS
lmao thats offa southpark when they had croc hunter on it hehehe but Croc. Hunter kicks **** anyway hehehe ... just the things he does... its hard not to laugh when an alligator or crocodile tries to takehis hand off or when a snake tries to rape his foot full of venom
its a damn lot better than watching MTV I tell ya that much
Old Jul 20, 2001 | 02:47 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
</font>
He's a wimp. Now go hunt a bear with a pocket knife...now that's tough.
Old Jul 20, 2001 | 02:52 PM
Blue502's Avatar
Maybe, but he has one of the best jobs on this planet.
Old Jul 20, 2001 | 03:02 PM
82Zee28's Avatar
Um yeah, show them your "pocket knife, Aaron. LMAO
Old Jul 20, 2001 | 03:03 PM
Demon Z28's Avatar
Car: 2001 Camaro SS
Maybe, but he has one of the best jobs on this planet.</font>
Very true hehehe
Old Jul 20, 2001 | 03:04 PM
Demon Z28's Avatar
Car: 2001 Camaro SS
Um yeah, show them your "pocket knife, Aaron. LMAO </font>
Old Jul 20, 2001 | 03:41 PM
OldBlue's Avatar
hum carb carb carb carb get a Edle Brock 1406 600 cfm carb w/ the electric choke I put one of these on my oldsmobile ( 83 delta 88 w/ the computer controlled carb ) I hooked up the choke but left the computer relay ( plug on the drivers side of the carb ) off and it ran fine. when I needed it to pass emmissions I would tune it back almsot to the point of running to lean after emissions jsut crank it back up to where it was before just remember how many turns you turn the needle valves and I also took a sharpie and maked where it was so the lines lined up and jsut rememberd how many turns I turned them in and when I turned them back out I did the same amount and then I would line the lines back up.
Old Jul 20, 2001 | 04:58 PM
Car: Death Mobile
Engine: 666 c.i.
Until he becomes the crocigator's lunch. That's one episode I don't want to miss.
"Rawght, and if we look up 'ere in the crocigator's stomache..."
Old Jul 22, 2001 | 07:17 PM
AmorgetRS's Avatar
I am glad Jesse is such a good Moderator and keeps these posts on subject!
Anyway, summer, you've seen my burn outs... just put it on Drive and floor it. Don't worry about shifting into 2nd or something. The idea behind a burn out with street tires to just clean them off from all the crud and get them a little warm... overheat them and they are all oily and slick... in the bad way.
Yeah, and NO Neutral drops... unless you want to drop your tranny while you are at it. I did it once in my V-6 when I didn't know better... and ouch... it made a horrid noise and I never did that again.
And nobody gets to woop Christys butt until I do in my V-6! That Firebird owes me a race, I never got to race it under Jesses control, so I will have to settle with racing a girl... sigh...
Old Jul 22, 2001 | 11:49 PM
F-BOY's Avatar
<font face="Verdana, Arial" size="2">Originally posted by AmorgetRS:
And nobody gets to woop Christys butt until I do in my V-6! That Firebird owes me a race, I never got to race it under Jesses control, so I will have to settle with racing a girl... sigh...[/B]</font>
Hey Doug don't ya thinks its twin should get first shot at it
speaking of burn outs, whats the easiest(on the car) way to lightem up with a stick
[This message has been edited by F-BOY (edited July 22, 2001).]
Old Jul 22, 2001 | 11:52 PM
Demon Z28's Avatar
Car: 2001 Camaro SS
lmao geez guys, picking on a new driver... thats mean...
She's currently a redhead, she'll run your *** off the road
Old Jul 22, 2001 | 11:53 PM
F-BOY's Avatar
hey Demon, I'm just a new Driver too man
Old Jul 23, 2001 | 02:10 AM
AmorgetRS's Avatar
Nah, I'll be so far ahead of her she won't be able to run me off the road!
As for its twin getting the first shot.. heck no! I race her, woop her butt, then I race you and kick you butt!! Then you two can fight it out for slowest V-6
Old Jul 23, 2001 | 02:25 AM
Crusader's Avatar
Car: 1988 Firebird Formula
Axle/Gears: 3.45
</font>
wha???
Now come on Doug we all now there is something way up with you supposed '3.1' plus you're lighter and have some goodies, so don't pick on the 2.8's so much.
And for burnouts, I just put it in 1st and watch the revs... For the stick guys I think what Lance did proably works the best, rev up well into power band - drop clutch to break loose - hit breaks to do the stationary part...
Jess
Old Jul 23, 2001 | 02:31 AM
Crista Jean's Avatar
hehehe...
Everyone will get a chance to race. Not to worry. But all you guys better watch out. I take after Summer a lot!
Just thought I'd let you all know.
I have to get the hang of the car first. So then I can really smoke ya'll!!!
[This message has been edited by Crista Jean (edited July 23, 2001).]
Old Jul 23, 2001 | 03:34 AM
Crusader's Avatar
Axle/Gears: 3.45
So I take it your buying it? You know when your gonna be up to pick it up?
Old Jul 23, 2001 | 09:55 AM
82Zee28's Avatar
Crista Jean the race machine!!
Jesse-Yes, she wants the car for sure. She plans to fly back up here between the 28th and 2nd. So, we'll hook up before you leave for Spokane.
Old Jul 23, 2001 | 07:56 PM
Crusader's Avatar
Axle/Gears: 3.45
Sounds good, I'll make sure it gets a bath the day before you come up for it
Old Jul 23, 2001 | 08:08 PM
82Zee28's Avatar
You're too kind to us. But you don't have to wash it. When we get her home, we're going to detail and wax it. Not that it needs it, it's such a clean car.
What I really want to know is what mods are you and your uncle planning with all that cash?? You're getting the money a few days before you leave, so...better start planning!
Old Jul 23, 2001 | 10:07 PM
Crusader's Avatar
Axle/Gears: 3.45
I'm still gonna wash it for you And I can return to you your steering wheel puller I meant to return when we met in Stanwood so Crista could drive the car.
HAHAHA my unlce promote go fast mods?! That will be they day - when my uncle helps me plan a mod... But, no mods are planned with the $ from the 89 unless you count paying down the loan or credit card a mod. But me, well the first thing is first - the next few checks will be saved for a 5-speed equipted parts car. Then LCA's/Subframes... Then saving for the BIG mod 400 SBC
Jess
[This message has been edited by Crusader (edited July 23, 2001).]
Old Jul 24, 2001 | 11:37 PM
F-BOY's Avatar
Hey Doug wouldn't be even funnier if her lil'6 took the win - ya never know
Old Jul 25, 2001 | 01:24 AM
Yeah Doug, you better watch out!!!
hehehe
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Mutillator
Exterior Parts for Sale
Oct 1, 2015 06:05 PM
Chevy3shitty
Sep 1, 2015 02:10 AM
beast94
Aug 20, 2015 06:44 AM
Bob88GTA
Aug 18, 2015 03:31 PM
