Pacific Region Regional board for Pacific Third Gen owners.
AN fittings
Old Dec 7, 2004 | 05:41 PM
pvt num 11's Avatar
Car: 1989 TTA
Engine: LC2
Transmission: Worn-out 200R4
Axle/Gears: BW 9-bolt, 3.27's
AN fittings
I have 24 9/16" AN nuts and tube flare thingies, the little part that actually applies the torque to the flare itself. They're aluminum, if that means anything, and they're unanodized. If someone has soem Alumniprep and some Alodine, they could be anodized pretty quickly, if they wanted to. If anyone is interested, I'd be willing to part with them for pretty cheap, maybe the whole bag for a small part or whatever. They're just going to collect dust on my bookshelf for years if I don't just toss them. Lemme know.
-Ian
Old Dec 8, 2004 | 11:08 AM
pvt num 11's Avatar
Car: 1989 TTA
Engine: LC2
Goodness, no one wants these things? I found another twenty in my desk drawer, and I even have a few odd-ball sizes, too. Spring cleaning came pretty early for me, or very late, depending on your point of view. Even found my Leatherman Wave!
Old Dec 8, 2004 | 02:52 PM
stew'86MCSS396's Avatar
Car: '86MCSS
Engine: 396 .030"
Transmission: M20
These are AN -6? I prolly could use a few of them, not all 24! lol stew
Old Dec 8, 2004 | 05:40 PM
pvt num 11's Avatar
Car: 1989 TTA
Engine: LC2
I'm not terribly sure what the AN-# size is. They don't say. I have four that have 7/32" nuts. Tiny, I'm sure they wouldn't even be good for brake lines. We'll have to have an AN expert look at them, because I'm not.
Old Dec 8, 2004 | 06:14 PM
Car: '86MCSS
Engine: 396 .030"
Transmission: M20
Okay, don't know what happened when trying to edit my post...
Anyhoo...thought about it and if a 9/16" wrench fits, then it's a -4 not a -6. Don't think I'll need anything that small for fuel lines. stew
Old Dec 8, 2004 | 08:33 PM
Duck's Avatar
Moderator/TGO Supporter
Car: 87 IROC 92 Z-28 91 Ragtop
Engine: 5.7
Transmission: 700-r4
Originally posted by stew'86MCSS396
If a 9/16" wrench fits on the nut, then it's a -6. Hydraulics isn't my forte...wondering if I gotta use aluminum with aluminum. Dissimilar metals tend to promote corrosion. Cheap is good but gotta think safety first and got some reservations on using aluminum tubing for fuel lines, too. I'd like to run stainless but the parts cost a little more. Anyone want to chime in? stew
Always best to keep the mating surfaces the same material, or at least materials that are compatible [like brass/iron]. In the case of fuel lines, I opted to use steel AN fittings, both welded and flared on the tank side, since it is hidden from view and not usually opened for work. If I were to use AN fittings inside the engine compartment, it would be nothing but stainless or steel. High pressure lines at 50 psi can shoot a lot of gasoline everywhere, heh. But I'm not the expert, do some browsing up at Earls or Russels, I'm sure the answer is over there...
Here's a link to my fuel lines with AN fittings and a recommended solution for 3rd Gens.
https://www.thirdgen.org/techbb2/sho...0&pagenumber=2
Old Dec 8, 2004 | 10:52 PM
3rdGenBlackBird's Avatar
I'll give you $20 for the leatherman, hehe.
The fittings are probably plenty strong for fuel. Check out Ed's (Duck) thread for more info on that.
Scott
Fronzizzle
Feb 9, 2017 09:31 AM
New2Chevy
Sep 28, 2015 12:35 AM
armybyrd
Carburetors
25
Sep 13, 2015 01:49 PM
BOOT77
Sep 5, 2015 03:55 PM
Formula_88AE
Sep 3, 2015 01:47 PM
