Pacific Region Regional board for Pacific Third Gen owners.
Water pump changed
Old Jul 17, 2005 | 01:37 PM
pvt num 11's Avatar
Car: 1989 TTA
Engine: LC2
Transmission: Worn-out 200R4
Axle/Gears: BW 9-bolt, 3.27's
Water pump changed
Ho boy, Buick stuff is wierd... Replaced the pump, pretty simple once I figured out all the little details, but it took us all day to do. My wife was really good at getting the stuff that was underneath. Note to the wise - do not try to remove the pump bolts without trying to get the pulley off first, this isn't your typical SBC water pump. Three of the nine bolts are underneath the pulley, and one of them is really long and can't be removed fully with the pulley attached. Fun day, I even have the sunburn to prove it!
Old Jul 17, 2005 | 10:13 PM
Duck's Avatar
Moderator/TGO Supporter
Car: 87 IROC 92 Z-28 91 Ragtop
Engine: 5.7
Transmission: 700-r4
Re: Water pump changed
Heh, first time I've heard of someone trying to remove the water pump without removing the pulley first ... especially because the water pump belt holds the pulley from turning while those 10-mm pulley bolts are cracked loose.
Old Jul 18, 2005 | 11:52 AM
pvt num 11's Avatar
Car: 1989 TTA
Engine: LC2
Yup, lesson learned there... The wife was invaluable for getting the lower intercooler bolts off and keeping me sane. Having a second pair of hands, eyes and brain lobes is priceless.
Old Jul 18, 2005 | 02:44 PM
acescarrsRS's Avatar
Car: 89 RS
Engine: 383 in building process
Sounds like you two had a lot of fun Good to hear that your wife got dirty with you!
eightsixseven
Dec 16, 2024 01:50 PM
evilstuie
Jan 9, 2020 08:29 PM
Dialed_In
Aug 20, 2015 01:45 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
