Pigtails for distributor with remote coil
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
I need the 4 plug and the 2 plug pigtails, as well as the remote coil wire and maybe the bracket to mount it if you have it.
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
well i can help you a little bit... i have the 2-pin and 4-pin connectors with a couple of feet of wire each, but that's all i got. i think i might have an "accel" coil wire, too. make me an offer...
KAM
KAM
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
I went through this a few months ago.
The "Black" side plug on the coil is basically impossible to find.
One place that I did find was outrageous for the cost.
Grey Side of Coil
GM# 12101896
Delco # PT166
Car-Pak #94-7305
Black Side of Coil
GM # (does not exist in catalog anymore)
Car-Pak # 94-7306
Black side connects to here (best to locate this part at JY)
Distributor 2 wire connector
(Same as Coolant Temp Sensor)
GM # 15306195
Delco # PT-169
Distributor 4 wire connector
GM # 12126487
Delco # PT-757
Car-Pak # 89-6707
Car-Pak manufacturing
1401 Axtell Rd.
Troy MI. 48099
(248)-280-1401
They only sell through this place
http://www.autobodysupplies.com
Look at section 11, subheading "I"
Grey Side of Coil
GM# 12101896
Delco # PT166
Car-Pak #94-7305
Black Side of Coil
Car-Pak # 94-7306
GM # 15306195
Delco # PT-169
GM # 12126487
Delco # PT-757
Car-Pak # 89-6707
1401 Axtell Rd.
Troy MI. 48099
(248)-280-1401
Car: 86 trans am
Engine: carbed 305
Transmission: auto
Axle/Gears: 9 bolt disc posi
Black wires
I have a few extra wires,the wire from the coil to dist,they are from a 6 cyl,Not sure if they are the same but they might be
badbob
badbob
Car: 86 T/A
Engine: HSR 355
PM me a priced shipped to 01611.
Thanks for the post JP86SS
I'm going to track down the 4 pin plug at a parts store, but I still need a coil, bracket, and the gray connector on the coil.
Same here but 2 pcs to 44136.
I wanted to make my MSD unplugable to go back to the stock setup if I had a problem. Wasn't able to do it cuz I couldn't find those connectors.
Thanks,
John
Thanks,
John
Car: 1976 Chevrolet Blazer
Engine: 383 TPI
Transmission: SM465
Axle/Gears: Dana 44 front, 12bolt rear. 3.73
Hey guys, I just saw this and thought I could help out since I went through this a few months ago. I actually found both wire pigtails (black connenctor and grey connector) at O'Reilly Auto Parts. When I first went in and asked about them they looked at me like I was nuts but when I searched their website I found the following Borg-Warner Part numbers:
PT251 (grey connector) $11.99
PT260 (black connector) $12.99
Yeah, they are certainly pricey but they're available!
Oh, the PT260 that goes to the distributor pickup does not have the connector on it that connects to the distributor!
Good thing I happened to have one!
Hope this helps save someone some time!
Good thing I happened to have one!Hope this helps save someone some time!
