Parts Wanted 2006 Looking for something in particular? Ask here.
Need Complete speed density TPI
Old Oct 31, 2005 | 10:38 PM
JRoy91RS's Avatar
Car: 91 RS Convertible
Engine: 355
Axle/Gears: 2.73 peg leg
LIke the subject says, I need EVERYTHING! Complete Harness, Distributor, TV and Throttle cables, ECM, etc. Let me know what you have or if you have a donor car you are parting out in my area, that would be even better.
Old Nov 1, 2005 | 10:44 PM
91CamaroRS305's Avatar
Car: Only a daily driver, but comin home
Engine: I have one that runs ;)
Transmission: Caged hamster that runs really fast
Axle/Gears: They are round, I know that much
i have a setup with a BRAND NEW (only installed to move the car before i took it out)Painless harness (with the instructions, and VATS bypass), it was on a 305 TPI speed density (MAP) car with a 700R4, it ran a drove nice, but it needs a new chip(the original is warped and unless you clamp/puch down on the cover for the chip it comes loose and the car runs goofy) i also have a set of Ford injectors for it (sorry i dont know the poundage on them but the came off a mild 350 i had), let me know, looking for $600 SHIPPED OBO (remember harness cost me $300+)
BTW it is the 4 foot longer harness so you have freedom to mount it where you want!!
Old Nov 1, 2005 | 10:47 PM
liteumup387's Avatar
Car: 1982
Transmission: 350
i have a COMPLETE tpi system everything your looking for in awsome condition it came out of a 91 camaro Z28 with a 350 ill take $550 + shipping
thanks,
john
Old Nov 1, 2005 | 11:48 PM
JRoy91RS's Avatar
Engine: 355
Do either of you have any pics? If so, please email them to me, if you can.
91 Camaro, does 600 include the ford injectors? Throttle/TV cables? Any sensors?
liteumup, where are you located?
Thanks to both of you.
Old Nov 2, 2005 | 12:19 AM
it included everything you need, including injectors, TB, runners, fuel rail, plenum, base manifold, distributor, cap/rotor, coil, and i have most of the gaskets to install(i may have all the gaskets, not too sure)basically everything you need except the O2 sensor(i think i may still have the manifolds with it in it, i need to look) and all the other sensors, the only one i am missing for sure is the ones in the trans(which any 700r4 should still have) the coolant temp sensor, knock sensor(and any sensor mounted to the heads/block) otherwise i have a new MAP sensor for it, other than that it has all the sensors still attached to the plenim and stuff....oh and it comes with an airfoil, forgot that, i dont have a throttle cable, but i may have a TV cable i need to look, and pics i will get tomorrow, i need to dig the parts out of storage
basically you will need a knock sensor, engine temp sensor, spark plug wires and spark plugs, throttle cable, and you MAY need an O2 sensor and TV cable, i will check on those 2, but let me know if you are interested
Old Nov 4, 2005 | 04:57 AM
91bbz's Avatar
Car: 1991 z-28
tpi
I have got a speed dens. out of a 91 z 5.7, includes, intake ,runners, plenum with throttle body,fuel rail,injectors,distributor,coil, all sensors are still on the unit, also have a 730 ecu for the set up, I went to carb,, like to get $250 for it...
Old Nov 4, 2005 | 01:42 PM
pr0zac's Avatar
Car: 1991 z28
Engine: forged 385 with afr's
Transmission: built 700r4
Axle/Gears: 9" and 4.56
Re: tpi
you got the harness?
Old Nov 4, 2005 | 10:08 PM
JRoy91RS's Avatar
Engine: 355
I've decided to buy from someone locally, so I am no longer looking for a setup. Thanks everyone for your response!
Terrell351
Jun 13, 2021 01:13 PM
Steve78LT
Feb 24, 2016 12:15 AM
KO1
Aug 31, 2015 06:31 PM
Sanjay
Aug 12, 2015 03:41 PM
86Base
Aug 8, 2015 01:34 PM
