T5 trans
Car: 90 L98 IROC/87 LB9 NM5 1AZ / 96 TBI 350 700R4 XCAB S-10..LT1 SOON
Engine: L98/LB9/LT1
Transmission: 700R4/WC-T5
Axle/Gears: 3:73
T-5
I have a v8 T-5, but it is in Va. let me know if you cant find one, this trans is in very good shape and low miles, no leaks. Jeff.
Car: '88 Camaro
Engine: 5.7 L98
Axle/Gears: Borg Warner 9 bolt w/3.27 lim. slip
What would the shipping be though? I can't get rid of a driver's side door for shipping reasons. My zip is 93446. thanks, GN3 FBDY Daniel
Engine: L98/LB9/LT1
Axle/Gears: 3:73
Transmission
I shipped a supercharger to socal, weighed @ 125lbs, @$78 ups ground, the trans weighs @ 80lbs or so, I will weigh it tomorrow and give you an estimate, I am going to say @400.00 to your door.
Engine: L98/LB9/LT1
Axle/Gears: 3:73
Transmission
I am asuming on the weight for the shipping, I have the trans in my truck, and will stop by the post office tomorrow, I will not have time today, and give you the total with shipping, Thats @ $400.00 for the trans, to your door, including shipping, which may be a little more, remember I am guessing on the final weight, and let you know saturday.
Car: '88 Camaro
Engine: 5.7 L98
Yeah, let me know! What motor is it behind right now? I'm looking to put it behind a 305 from a 84 H.O. Z-28 motor. It's eventually going to be a power plant for a rat rod. Do you know if that combo will bolt up? I ask because it had a 700R4 behind it before. Not sure if there are adapter plates needed to make that work. I'm new to the nuts and bolts section of the hot rod world, but am enjoying learning about the subject. I figure a rot rod will be a good project to learn on. Any info you have will be appreciated.
Engine: L98/LB9/LT1
Axle/Gears: 3:73
trans
It came out of an 84 Trans Am, 80k miles, that was the original miles. I also have a bell housing for the v8 t5, for $65 more that includes shipping to your door, it is in a box already. and all you will need is the flywheel, clutch setup and pedals, I think I have the tourque arm mount, and the console 5-speed shift plate too.
Car: '88 Camaro
Engine: 5.7 L98
Sounds very promising! Let me have a total with both trans and housing shipped to me in 93446 zip! GN3 FBDY
Engine: L98/LB9/LT1
Axle/Gears: 3:73
Trans
The trans is from a 305 car, it will fit all chevy small v8s, you will need a 2 piece rear seal flywheel, 83-86 v8 camaro or T/A, I do not have one of those, not too hard to come by, I will look and see what else I have for the swap, and make a list for you to what else you will need, its not too hard to swap auto to manual, you just need to get all the parts prior to starting the swap.
Engine: L98/LB9/LT1
Axle/Gears: 3:73
Transmission
I sent you a PM, with the info on everything, let me know soon, as I have another person locally very interested in it, you were first. Thanks Jeff.
1992 Trans Am
May 10, 2023 07:19 PM
Hawk312
Aug 22, 2017 08:55 PM
Hello, Michael
Aug 20, 2015 03:19 PM
