Parts Wanted 2006 Looking for something in particular? Ask here.
Buying Only rear Eibach Pro lowering springs
Old Jan 20, 2006 | 08:23 PM
Quick-IROCZ's Avatar
Car: 1987 IROC-Z28
Engine: 305 Tpi
I need 2 rear lowering springs. I don't need fronts; I have them already and I can't afford to buy a new set.
PM or contact justkazuke@hotmail.com
I bought it with the ******* rake look same size wheels too
Old Jan 23, 2006 | 11:20 AM
bubba353z's Avatar
Car: 07 Honda CR-V
Engine: Yes, there's one in there...
Transmission: One that shifts itself
It might be difficult to just find rears. If you are still looking come spring, let me know. I'm going to pull my Eibach kit in a few months, and we might be able to work something out.
You can also try removing the rubber isolator, and use heater hose over the end of the coil (I can't vouch for it, but I heard it works). You can also progressively cut the coils, and shorten the spring. Use a saw (don't torch it), and go slowly - once it's cut you can't add it back on.....
Good Luck
Old Jan 24, 2006 | 01:03 PM
Car: 1987 IROC-Z28
Engine: 305 Tpi
It's great to see i've finally been noticed lol. Is there anyway these springs could have gone bad and would give me a reason to buy a new set? hence 50-100 more, because i don't have the time, no offense at all, i can't wait to get this on the road.
the springs in the front are supposed to lower it by one inch, but I think it's 2 inches now...is that possible with the weight from the engine? Thanks
Old Jan 24, 2006 | 06:50 PM
bubba353z's Avatar
Car: 07 Honda CR-V
The springs are probably OK - unless your running a big block, the engine weight probably shouldn't be an issue.
Eibach has two different spring sets, Sportlines and the Pro Kit. I think the Pro kit is about 1.5" drop and the Sportlines a 2.5" drop. You may have the Sportlines and not know it.
I'd go ahead and cut the rear springs, if it's really a problem. Maybe you'll get lucky and find some rears. I actually like the look of my Pro Kit, but my Spohn TA hits the tunnel with them. I'm going to clearance the tunnel when I'm getting the 10 bolt rebuilt, but I've got a set of WS-6 springs warming up in the bullpen - just in case.
customblackbird
Aug 15, 2021 10:16 PM
draco
Oct 4, 2015 09:25 PM
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
sailtexas186548
Aug 26, 2015 03:32 PM
86White_T/A305
Aug 17, 2015 12:16 AM
