4-PIN distributor wire harness needed
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
I need the 4-PIN wire harness that connects to the ignition module in the distributor that goes to the ECM. This is for a 5.7 TPI engine. Realizing that it is part of the main harness and goes thru the firewall to the ECM, I'm throwing this out there if someone happens to have an old hacked harness with that part still intact, or if someone has a used harness they want to get rid of (application won't really matter as long as it is same type HEI). I have a short in that part of the harness, and it's probably in the bundle going thru the firewall, but...
Car: '91 Z28
Axle/Gears: 323's
sorry, no pic... not really a seperate harness, it's integrated in to the main harness, only has about a 12"-15" pigtail going to the dist, pretty much behind it.
