Parts Wanted 2006 Looking for something in particular? Ask here.
need a pulley to replace my air pump!
Old Feb 25, 2006 | 06:13 PM
355tpipickup's Avatar
Car: 92 1500p\u 2wd
Engine: 91 z28 tpi 355
Transmission: 91 700r4
i took my air pump off befor i droped the motor in my truck and im using a v6 belt on the motor now...seems to work great! but i just got soem underdrive pulleys and im not sure what size belt to get when i dont have a air pump so im lookin for a pulley to put back in place of my air pump!! or what size belt do i need for underdrive pulleys and no air pump...on a 91 z28 motor!! thanks
Old Feb 25, 2006 | 07:33 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
you can get any length belt you want at any parts store.,
simple
good luck
Old Feb 25, 2006 | 08:23 PM
Don 79 TA's Avatar
Car: Hers: 88 Formula 350
Engine: TPI
Axle/Gears: 10 bolt Posi
take a look at an 89 tBI 5.7 full size Balzer/Jimmy setup for belt routing
March also sells under drive pulleys for that, and would probably list the belt too
you dont really need the pulley if you route the belt
Old Feb 26, 2006 | 09:00 AM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
the vans too
a friend of mine just took a 92 ful size 2500 gmc van with 5.7L TBI to shredder friday or saturday,
ran good even, had the later true serpentine on it with aluminum brackets, the good stuff, and smog delete
shredder, gone
good luck
justin57
Aug 20, 2015 07:05 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
mcquigg
Aug 13, 2015 02:26 PM
92purpz28
Aug 11, 2015 02:30 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
