Who has the pics of that ebay twin build??
Old Jan 17, 2009 | 06:41 AM
Excellegions's Avatar
Car: 91 Camaro TBI 5.0
So much discussion about the two types of twin turbo headers on ebay, has anyone attempted it? Where are the pics??
Old Jan 17, 2009 | 12:04 PM
project89's Avatar
Re: Who has the pics of that ebay twin build??
ebay twin turbo headers do not fit the 3rdgen
one set puts the turbos threw the hood
and the other set hits the steering linkage.
Old Jan 17, 2009 | 12:42 PM
So if you go with aftermarket power steering or no power steering, then that one just might be able to be used, you think?
Old Jan 17, 2009 | 01:15 PM
project89's Avatar
no the linkage is still in the same place it still hits.
one person on these boards used them, but had to cut up and reweld the ds header
also iirc he used the headers and built a crossover to make it into a single turbo setup
used as twin turbo setup i do belive either the turbos or the downpipes will end up hitting the subframe
the only ebay header that directly fits is the bbs knockoff single turbo header
Old Jan 17, 2009 | 06:07 PM
tpi user's Avatar
hey project i cant find that ebay bbs knockoff. got a link? thanks
hey project got a link i cant find it thanks
Old Jan 17, 2009 | 06:20 PM
project89's Avatar
there are none listed right now, just search ebay for chevy single turbo header
Old Jan 17, 2009 | 07:14 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Originally Posted by tpi user
hey project i cant find that ebay bbs knockoff....
.... do you mean these?
Old Jan 17, 2009 | 08:00 PM
project89's Avatar
those would be the only ebay turbos that do fit ^^^^^^^^^^^
Old Jan 19, 2009 | 04:19 PM
Car_2's Avatar
Car: 89 Trans AM & 69 RS/SS Camaro
Engine: 400 "little M"
Transmission: Tremec TKO II
Axle/Gears: Moser 9" with 3.50's
i bought the twin turbo ebay manifolds, thinking i could chop them up and it would save me the work. After i mocked them up, i decided to build my own. The twin kit is definately not a "bolt on" if you use it in the stock configuration, the turbo's run into the radiator, and they don't fit the 88-92 brackets and pullies either. Not saying you can't chop them up and make them work, but i didn't like how it would look.
Old Jan 19, 2009 | 04:52 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
I'm making my own twin setup but it more than likely wont work with factory serpetine setups and definately not with AC. Will post results whenever i get around to fabbing them up
Old Jan 20, 2009 | 07:22 PM
tpi user's Avatar
ya street lethal those seem interesting what do you guys think of those?
Old Jan 20, 2009 | 07:40 PM
project89's Avatar
they arent bad and will get the job done, but i suggest taking them to a welding shop and having the welds gon over and cleaning up the inside of the collector with a die grinder
Old Jan 20, 2009 | 08:39 PM
86trbota's Avatar
Car: 86 trans am
Engine: 383 dart 215 billet 84mm s400
Transmission: th400
Axle/Gears: 3.08
im knew to this site but have been on the turboforums alot. i bought one of the ebay twin turbo kits and they will not work with the serpentine belt system i am in the process of cutting up the headers and making the turbos mount by the calve covers. the kit is pretty decent for chinese stuff and i know of 6 of those turbos runnin around and not a single one has blown up and they will support 450hp a peice at 20psi
Old Jan 20, 2009 | 09:17 PM
project89's Avatar
the correct way to have put that is they will support 450 each,its actually a lil closer to 425 though. if they were 57 trims they would do 450 each
Old Jan 21, 2009 | 12:46 AM
86trbota's Avatar
Car: 86 trans am
Transmission: th400
Axle/Gears: 3.08
sorry guess i should have worded that differently
Old Jan 21, 2009 | 01:04 AM
project89's Avatar
i meant by u saying @ 20 psi it dosent take 20 psi to get 450hp each from one of those turbos. it depends on the motor.heads/cam etc.
by saying 2 of those used as twins u need to hit 20 psi to reach the max on each turbo is gonna mislead ppl
Old May 31, 2009 | 08:19 PM
firstfirebird's Avatar
Well we have pics now don't we Lee?
The DS header hits the steering as mentioned and the pass side hits the A/C box.
I'll post some pics in a bit.
Old May 31, 2009 | 08:25 PM
We sure do! About Damn time!!!! Lets give em what they want.
Old May 31, 2009 | 08:26 PM
I forgot to write that check out to you too!
Old May 31, 2009 | 11:22 PM
Old Jun 1, 2009 | 11:17 AM
Eats5.0's's Avatar
Car: 84 Berlinetta
Engine: junk 350
Transmission: TH350
Axle/Gears: Moser 4.56
Thanks for the pics. Tells a true story. I'd hate to try to fab up an STS clone, since I really wanted to run the SLP Loudmouth. But, that may have to get sacrificed for power.
Old Jun 9, 2009 | 12:28 AM
chevytoyr1's Avatar
Old Jun 10, 2009 | 10:40 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
i have some also. Just have to dig em all out.
I bought all the ebay setups to test fit.
like the picture above show. They just squeeze in. I think I would fit a thin piece of cardboard between the steering shaft.
Old Jun 24, 2009 | 04:52 AM
drknow90rs_ss@y's Avatar
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
Bummer. I was looking at those ssautochrome headers too... I was hoping they could be made to work, but I guess I will have to stop being lazy and just make my own like orr89rocz did. (His turned out great, BTW...)
Old Jun 24, 2009 | 06:36 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
mine sit too high if you want to keep them under the hood. with a 4" cowl and elbow style intake setup, you can tuck the turbos inward more and get both to clear under the hood with a similar manifold to what i have. If i could do it all over again, I want to make the turbos out in front of the motor more
Old Jun 24, 2009 | 10:50 AM
We are going to MAKE them work
Old Jun 24, 2009 | 11:54 AM
Bummer. I was looking at those ssautochrome headers too... I was hoping they could be made to work....
They can be made to work....
Old Jun 25, 2009 | 02:06 AM
Thats what I was thinking... I will most likely run a "stabil-trac" or similar system for my accessories. I definately want to keep my a/c and I will be relocating my coolant tank and getting rid of the windshield washer tank. Battery has been relocated, so I have some room to play with.
I am trying to keep it all under the stock T/A 4-vent hood. (And maybe look into making the two front vents functional as intakes)
Right now, most of my concentration is going into the mini-tub and suspension (Narrowed fab-9" with stock-style suspension)
Old Jun 25, 2009 | 10:46 AM
Warrior's Avatar
Car: 98 Camaro/85 Camaro
Engine: 3.8L/ 355 CI
Transmission: Auto/ TH350
Axle/Gears: 3.23 Posi
Wheres the radiator going?
Old Jun 25, 2009 | 04:09 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Thats gonna make it much harder to do but if your good at fabbing things and have lots of time and creativity you can get things to work out just fine. Lots of room under the nose of these cars. Relocate radiator abit more forward and you can get some turbos in the front easily for a twin setup.
Single is easier to do period but twins are cooler IMO.
If I was to hang my turbos out in front more I probly could get it to clear the stock hood just fine. Many others have done this, just have to be picky on your accessories and good with downpipe fabrication. If i was to move my turbos over the valve covers more, i could fit both turbos under the 4" hood but downpipes would be abit harder to pull off where I ran them now.
Old Jun 25, 2009 | 11:15 PM
The accessory drive that I am thinking of puts all the accessories within the perimeter of the front of the engine. I'm hoping I can put the turbos in almost the same area that the a/c compressor and alternator were. I am most concerned with cooling. I also dont want to cut the front bumper cover up. (Really want to keep the stock appearance, despite the 275/30R18 and 335/25R19 tires, LOL) Have to figure some way to get air to the radiator, condensor and intercooler.
Old Jun 25, 2009 | 11:21 PM
I'm betting the radiator is going in front of the core support. That looks really clean....
Old Jun 27, 2009 | 02:01 PM
85camaro350v8's Avatar
Car: 1985 Camaro Sport Coupe
Engine: Twin Turbo crate 350
Transmission: TH350
Axle/Gears: still workin on that
looks really good but,........am i the only one that noticed the upside down valve cover
Old Jun 27, 2009 | 04:04 PM
Actually it's right-side-up if you want to keep clear of the downpipe
Old Jun 28, 2009 | 02:10 PM
Transmission: TH350
i just noticed that lol
Old Jul 1, 2009 | 09:46 PM
turbobike's Avatar
Car: 87 WS6 Firebird
Sort of like this...
Old Jul 1, 2009 | 09:59 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
Got any pics with the giant holes in the hood? Looks nice. Why two different colored compressor outlet silicone couplers?
Old Jul 2, 2009 | 06:16 AM
I would also like to see what you did about the hood issue on that 'bird. Show us more!
Old Jul 2, 2009 | 06:25 AM
turbobike's Avatar
Old Jul 2, 2009 | 05:17 PM
junkcltr's Avatar
Engine: 3xx ci tubo
That looks decent. On most cars it wouldn't look good because a lot of the turbo would stick out. The 3rds have a lot of hood clearance because of the TPI unit being so tall.
Are those China T4/T3 hybrids or something else? They look like china T04E 46 trims with the T3 turbine.
Old Jul 2, 2009 | 06:38 PM
Hey junk, how you been?
I agree they look just like the turbos I have, and that are going on Lee's car (Excellegions), except with Lee's, we are doing internal wastegates and a unique downpipe setup. With the narrow angle v6 in my car, it was tough to get both turbos under the hood, but I didn't want to cut my hood, but I will have to say that, turbobike, that is clean for a cut hood! Did you do anything to keep the edges from rusting?
Old Jul 3, 2009 | 03:20 AM
  #42
WOW!!! Turbobike; That looks really good! Love that you kept the "5.0 FI" sticker. Maybe, in this case it means "Forced-induction"! LOL. Whats that near your coolant bottle? Air filter? More pics, please. Very nice!
Old Jul 4, 2009 | 09:08 AM
  #43
junkcltr's Avatar
Engine: 3xx ci tubo
Things have been going well. How have you been? Still building turbo setups? I haven't done much with the cars lately. I started collecting parts for a Kawasaki on/off road motorcycle turbo project. I have been wasting a lot of time reading the MS1 code trying to figure out how I can make it work with a 2 tooth - non-uniform trigger wheel.
Is your camaro still turbocharged?
Old Jul 4, 2009 | 09:46 AM
  #44
Well it the Firebird WILL be eventually haha. Twin ebay turbos with home made headers this time, but it's a slow process since I have started doing the V6's as a part time job. Started out where I was building turbo kits, TB adapters, flanges etc to fund the 'Bird, and now has blown out of proportion and don't get much time to work on my own stuff anymore.
Right now have a '93 Camaro 3.4 here that was shipped from VA for a full resto-mod using the FWD aluminum top end parts, full tubular rear suspension, Moser center section guts, aluminum rear drum conversion, Performabuilt tans with 3200k stall, tubular k, tubular upper and lower control arms, sub frame connectors, Corvette front brake conversion, cam, headers, exhast, pretty much the works. Right now I am in the middle of doing the OBD1 non-PROM ECM swap to a '9396 OBD1 so that I can grasp the tune before pulling the motor/trans out. This way I have a running engine (crate) to make sure the ECM swap goes well before swapping the top end/cam. In the end it should be a quick V6 with a few suspension modifications, lightened quite a bit, high flowing heads, 11.5:1 SCR and a powerplant that tips the scales at 340lbs. Once I get all the major work completed the owner is interested in having my friend paint the car and have a carbon fiber hood/spoiler installed so he can eat up some LT1's haha.
Then I also have my '86 BMW that I am contiplating swapping in a GM ECM so I can tune for the newer, better flowing top end and cam I have for it. The ECM in there now is tunable, but don't have the luxury of a one-point datalogging port like we do with the GM ECM. It should be fun to see how the car is after gaining another 80hp (180-200 up from 110) or so in a car that only weighs about 2700lbs.
I gather the the bike has some type of DIS or coil-on-plug rather than a distributor?
Also just built a JAW, and it's working flawlessly. Can't beat a programmable wide band controller with display for less than $100
Couple pics of my twin build...
http://s448.photobucket.com/albums/q...rbo/?start=all
Old Aug 2, 2009 | 12:00 PM
  #45
hotrod78's Avatar
Car: 1986 Trans-Am
Engine: chevy 350
Transmission: TH350
did you have to modify your carb to work with the turbo setup
Old Aug 17, 2009 | 05:39 PM
  #46
Transmission: TH350
heres mine im using the upward mount headers. these hit the brake booster, but im getting a smaller one. Im about to start the motor and put 1000 miles or so on it, before it sees any boost
Attached Thumbnails Who has the pics of that ebay twin build??-pic-0664.jpg   Who has the pics of that ebay twin build??-pic-0692.jpg
Old Aug 17, 2009 | 07:32 PM
  #47
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
how come no rear mount twin turbo setups? no need for intercoolers and theres alot of room in the back of the car? i was thinking about it for my HSR383. wat size turbos would you guys run? should make NA 480hp. i was thinking 700hp be pretty nice maybe some T3 hybrid T4's? wat are some cheap china turbos?
Old Oct 26, 2009 | 05:22 AM
  #48
Money has been crazy, and holiday seasons are not making the project go any faster, but Im still working on it people! have not given up yet!! I will post more pix, I slightly bent the pipe that was touching the steering column inward, cleared that, and working on the custom power steering unit as you can see in the pic. solutions for ac compressor and aleternator brackets are next. Hey John, we gonna be needing those idle pullies on both sides of the waterpump very soon!!!
Old Oct 26, 2009 | 05:27 AM
  #49
Hey John!!
If you notice the hole where the battery tray is, Im planning on having the downpipe go out of the turbo, go down that hole, swing around and back into the engine bay. you can see that pipe that is running under the deader on the driver side, when the pipe comes back into the bay it will run back under the header and down. I want to do the exact same to the other side. Gonna need your pipe bending specialties.
Old Oct 30, 2009 | 02:18 AM
  #50
Imthebriman's Avatar
Car: 1991 Camaro Z28
Engine: L98 5.7 350 TPI
Transmission: Brand New (again) 700r4
Axle/Gears: GM 10 bolt 7.625 W/ TrueTrac 3.23
John is definitely the man with the plan. Wish I was still down in Boynton Beach so he could still help me with mine....
