Nitrous and stock timing question
Old Apr 28, 2002 | 11:29 AM
GKK's Avatar
GKK
Car: 91 Camaro RS Update: Sold Camaro, now own a "91" Corvette.
Engine: Corvette L98 TPI
The stock timing is 0* so, if I add a 100 shot NOS kit would it be alright to keep the timing where it is? On the NOS site it says the stock timing does not have to be changed using their kits.
Old Apr 28, 2002 | 12:37 PM
Chronos_Titan's Avatar
If you are running 0* timing you should be fine.
Old Apr 28, 2002 | 12:41 PM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
Your stock timing is 0*? How slow is your car? w/ that timing you could run a 150 shot and not have to change a thing as far as timing goes.
Old Apr 29, 2002 | 07:38 PM
IROCKZ4me's Avatar
Car: '86 IROC-Z + Misc. project cars.
Engine: Supercharged + Nitrous TPI 355 CID
Transmission: Art Carr built Th700r4
Certain F bodies are timed (base timing) at 0° BTDC after disabling the ECMs timing control by unpluging a wire connector near the distributor. On those certain cars, that is the stock spec for base ditributor timing with no input from the ECM. When you plug the wires back together the ECM then adds the timing advance that it is calibrated to.
I'd say that is the 0° he's talking about.
Old Apr 29, 2002 | 08:28 PM
vortech305's Avatar
a
Old Apr 30, 2002 | 09:59 AM
GKK's Avatar
GKK
Thanks IROCKZ4me, thats what I meant about my stock 0* timing. Does the computer compensate for the added nitrous and add the appropriate fuel?
Old Apr 30, 2002 | 10:57 AM
IROCKZ4me's Avatar
I don't know which NOS kit you are using, but they have produced a few different styles over the years.
A wet kit injects both nitrous and fuel, using a seperate nitrous solenoid and fuel solenoid. The ECM has no way of "knowing" the wet system is there.
A dry kit injects only nitrous and requires the original fuel injectors to supply the needed extra fuel.
NOS has made two different type dry kits that I know of. The first used an electronic module that plugged into the stock ECM to alter (increase) the pulse to the fuel injectors when the system is activated. Opening the injectors longer supplies the extra fuel. The other used a mechanical device that used nitrous system pressure to increase the stock fuel pressure regulators pressure when the system is activated. With this type the ECM doesn't know the nitrous system is there either.
Old Apr 30, 2002 | 12:16 PM
GKK's Avatar
GKK
I want to get the Wet NOS kit 05153 for my 305 tbi. I'm running 12psi fuel pressure with other mods in my signature.
MustangBeater20
Oct 29, 2022 09:20 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
redmaroz
Aug 16, 2015 11:40 PM
Exxon Limited
Aug 9, 2015 08:13 PM
