how much boost
Old May 5, 2002 | 01:05 PM
86maro305's Avatar
how much boost
how much boost could could a stock zz4 handle and could i also run n2o safely.
Old May 12, 2002 | 02:33 PM
86maro305's Avatar
ttt, and also what is the red line on this motor.
thanks for the help,
Dustin
Old May 15, 2002 | 01:33 AM
marhornetmech's Avatar
Car: '89 rs t-top/ '78 firebird/ '94 Z-28 convertible
Engine: 305 carb./ 350/ LT1
Transmission: T-5/ TH350/ T-56
305 with 600 cfm carb...you're probably gonna need to flow more cfm's than that for pretty much any power adding setup. Also can't see your sig from this reply board, but you'll want a "bigger" cam when you add power adder, which will need the more cfm's also.
Old May 15, 2002 | 07:11 AM
onebinky's Avatar
If you go big enough where the motor is real "lopey" then you will loose alot of your boost. The reason being is that your intake and exhaust valves would be open at the same time for a short moment, and the boost would travel straight thru.
Matt
Old May 15, 2002 | 01:23 PM
what onebinky says is true and for this reason i think you don't want less than 108 degrees of lobe separation, but you'll have to recheck my numbers because i'm not positive, just wanted you to know that you're going to need more air and fuel when you add turbo, supercgarger, or n2o.
Old May 15, 2002 | 05:49 PM
daverr's Avatar
this is not completely true.it all depends on the application,the motor.if this is going to be street motor the zz4 should be set for 10 psi tops or 150 hp shot.
dave
$750 L98
Feb 1, 2025 02:25 PM
seiplentz
Aug 19, 2019 06:02 PM
customblackbird
Oct 1, 2015 04:30 PM
Dragonsys
Sep 25, 2015 03:51 PM
Doobie52
Sep 11, 2015 06:19 PM
