Nitrous HP cams? Any good?
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
I need a better cam w/ more dur. than my ZZ4 cam. I was thinking about the Nitrous HP cams that Comp Cams makes. Is anyone here running them or have thought about using one. I plan on spraying 100 shot from my NX kit.
My goal is to have a 11 sec. car I can drive to work everyday. Do you think this will help.
PS- I got better valve springs that can handle .600 lift and 7500rpm. I also installed a set of 1.6RR.
Engine: 355
Axle/Gears: 4.11
I was thinking of the 230/244, but I don't want anything under .500 lift. With my 1.6 rr on now I got .506/.544. But I only have 208* 221* of duration. I want it to lope pretty bad. I was thinking of a cam that was around 230-240*. What do ya'll think?
CarGuyDennis
137
Dec 6, 2016 11:02 PM
