0 - 63Mph
Old Jun 6, 2002 | 06:30 AM
Bratwurst's Avatar
0 - 63Mph
Greetings from Sweden
I have a small question for you Pontiac TA experts reading this forum :rockon:
My Trans Am GTA -87 350TPI, needs almost 7sec to accelerate from 0 to 100 Km/h (0 - 63Mph).
I planned getting a Vortech or ATI compressor, but buying and installing one would cost more then the TA itself
NOS is "not" an option in my car!
So what can I do to increase the effect without spending too much cash¿ Thx :hail:
Old Jun 6, 2002 | 09:30 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
I know there are mechanics over there or maybe yourself that are competent enough to do the following. I would recommend a purchase of the new GM L31 heads (with performance spring upgrade), the new high performance, specially adapted (to work with L31 heads), lower "base" TPI manifold, and GM HOTT cam and GM rockers from www.sdpc2000.com ( a GM race parts dealer). Then a set of the siamese style SLP TPI "runners" for your manifold, a larger throttle body with 52mm openings (Edelbrock/BBK), K&N air filter, B&M transmision torque converter part# 70419 (I included this part# because they are hard to select), March performance under drive pulley or pulleys (which ever is offered for your application), a Hypertech thermomaster; chip, thermostat, and fan switch all from www.summitracing.com . I believe the price of these items may be less than the blower and its installation. also, I have listed two different companies here because first of all I believe they both can ship overseas, secondly because one has some of the parts needed and the other has the rest of them. this should solve your acceleration problems.
Old Jun 6, 2002 | 09:56 AM
Bobalos's Avatar
if all you are concerned about is 0-100KM & not mileage or streetability, then Converter, Rear Gear & some tires ought to make a BIG dent in that 0-100KM time. The flip side is mileage, & wear on the tires.
BW
Old Jun 6, 2002 | 10:26 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
I though about suggesting gears but most gta's have 3.08's-3.42's wich is sufficient for intitial acceleration as well as for a european guy that likes to try to go 200+ KPH on the open road
Old Jun 6, 2002 | 06:19 PM
Bratwurst's Avatar
Awesome information B4Ctom1 :rockon: I will definitely look into these modifications!!
Many thanks for the advice
cuisinartvette
Jul 17, 2012 09:56 PM
SlowStangEater
Apr 28, 2002 09:26 PM
SlowStangEater
Apr 27, 2002 09:28 AM
L98IROCZ89
Jun 22, 2001 04:59 PM
