supercharging a 305!
Old Jun 21, 2002 | 06:45 PM
no_car_yet's Avatar
Can you do that without replacing all the internals. I am prob buying a 91 GTA in the next couple of weeks with a 305 and want to know how long would it last supercharged. What needs to be replaced if anything? Whats a safe amount of psi to run? How much power roughly do you gain with each psi turned up? Any help would be appreiceiated.
Old Jun 21, 2002 | 07:49 PM
nitrobreth's Avatar
how many miles?
Old Jun 21, 2002 | 08:45 PM
no_car_yet's Avatar
milage...
160,XXX kms , but most of them are highway miles...
Old Jun 21, 2002 | 09:02 PM
nitrobreth's Avatar
around 100,xxx miles right? i'd say if the motor is in good shape (no blowby, not leakind like a siff, no knocks) then you should be alright. replacing engine parts is never a bad idea. seals, springs, cams, and stuff like that wears out. try to replace whatever you can (as far as money will go ) and put a charger on it. prolly keep boost down to 6 or 7, not sure though. as far power per boost, depends. cam, heads, compression, intercooled. too much to guess. shoot out some more specs. (ie: model of blower)
Old Jun 21, 2002 | 10:27 PM
keen88gta
Guest
Posts: n/a
A little more info would be nice yes. But as far as the amount of boost goes if you follow what nitrobreth said and check for leaks and knocks I dont see any reason not to run 9 lbs at your 9.3:1 compression ratio.
just my .02
Old Jun 22, 2002 | 07:34 PM
no_car_yet's Avatar
Can you get a supercharger small enough to fit under the stock hood?
What kind/series of super charger would be goodfor a 305 TPI, auto. Ask any questions at all if you need more details. It already got flowmasters, and headers and a few other mods.
BTW; i'm making my offer on the car tomorrow, so wish me luck!!
pjsparts
Oct 29, 2025 06:39 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
rsrookie
Sep 5, 2015 07:08 PM
Formula_88AE
Sep 3, 2015 01:47 PM
