switch to LT1 intake for boost?
Old Jun 25, 2002 | 12:03 AM
CamaroFreak87's Avatar
Car: 1987 Camaro IROC Z-28
just wondering what your opinions on this are. keep the TPI and port runners/manifold or switch to the LT1 intake? considering boost is all in the intake of air and the LT1 intake is supposed to flow better, was wondering if there's a significant advantage to using an LT1 intake on boosted engines. Thanks.
Ryan
Old Jun 25, 2002 | 10:03 AM
89ProchargedROC's Avatar
you will only raisethe rpm band up higher and will need to also have a larger cam to match
only main difference is that you will be able to make your horsepower goal at a lower psi setting than if you used TPI
i was going to prove all of this but decided against it because TPI is just too much of a PITA next to the superram of course
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
1992Vortec
Aug 31, 2015 08:05 PM
86IROC112
Aug 17, 2015 02:00 PM
86White_T/A305
Aug 17, 2015 12:16 AM
