Can a carb NOS system be used for TPI?
Car: 86 Z28
Engine: 355 carbed
Transmission: t-5
A really dumb question but have to ask. I have a NOS compition shot up to 250 plate system. It is still sealed in the box. Now would someone with a fuel injection be able to use it. Lets say a 99 C5? The kit was $800 brand new and I am not going to use it and want to sell it. Where would be a good place?
Car: 1982 Z28 & 1967 RS & 2002 Z28
Engine: 388 ci SB / 454 ci BB / LS1
Transmission: 4 speed / TH350 / T56
Axle/Gears: '91 "1LE" rear, posi w/ 3.23's
NO, where is the "plate" going to go? and EBAY to sell it... someone might be able to get it to change over to FI, if they boutght enough "accesory" parts form NOS...
I could be wrong b/c I don't know a lot about nitrous, but I think a lot of Mustang boys buy the carb kits and use them on their fuel injected 5.0s. I know this b/c that is what my brother did. He bought a carb kit, then bought a different nozzle that looks kind of like a "Y" then drilled a hole in his rubber boot before the throttle body and somehow mounted the nozzle in it. I know you would have to buy the "Y", and probably a few other fittings for things like the schrader valve, but I think you end up saving atleast a couple hundred dollars. I think they do this b/c you can get certain carb kits alot cheaper than most fuel injection kits.
Car: 86 Z28
Engine: 355 carbed
Transmission: t-5
Yea I know that most carb kits are cheaper then fuel injection kits. I paid $800 for this kit from jegs. I am not sure if I want to put it in my car yet. If I do it would be easy and I will need a higher flowing fuel pump. I was jsut asking because I ahve a couple of friends with LS1 that want NOS in their cars and wanted to know what it would take to make this kit work.
Sanjay
Aug 12, 2015 03:41 PM
