REALLY strange turbo question...
Check this site out.
http://www.turborick.com/main.html
He's got a turbo'd motorcyle and under the technical section he's got one one converting a smog pump into a supercharger for a small displacement engine.
Look at the link I posted under the turbo stuff sticky. It has a turbo calculator that will give you a pretty good match to start with. It can also calculate compressor maps and such if you know enough about what you want.
This is what I got from it. 150 ci works out to 2450 cc's right?
MAKE TYPE COMPRESSOR TRIM TURBINE HSG A/R
Garrett T2 44 0.35000000000000003
