ProCharger Guys, Please Look
Old Aug 6, 2002 | 09:55 AM
StocRoc's Avatar
HI guys, I am just curious where you guys w/ ProChargers have your base timing set at. Also how many pounds are you running, and any problem w/ knock? Thanks for the help, I'm in the process of getting my P1 tuned.
Old Aug 7, 2002 | 10:09 AM
ZaphodB's Avatar
Car: Camaro IROC-Z '89
Engine: 350 TPI /w Procharger P1SC
Transmission: TH700R4 with Transgo shiftkit
Axle/Gears: 2.77 Borg Warner
Re: ProCharger Guys, Please Look
I run 6 degrees of base timing, and 10 PSI - No knock problems...
Old Aug 7, 2002 | 12:07 PM
StocRoc's Avatar
thanks, anyone else?
Old Aug 7, 2002 | 03:34 PM
maniacc's Avatar
I run 10#'s intercooled, 6° base timing, and see about 9° knock retard, but my sensor is the original one from the factory (14 years old), I've just been to lazy to change it, but I will be replacing very soon, along with a few other things.
later
larry
Cleotiz
Jan 6, 2018 08:56 PM
aaron7
Aug 17, 2016 06:02 PM
PestilenceIV
Aug 20, 2015 03:32 PM
Street Lethal
Aug 14, 2015 08:25 PM
85Iroc-Z
Aug 13, 2015 01:58 AM
