carb hats and projection TBI ??
Where can I find a carb hat and does anyone know how much boost a Holley Projection TBI unit can take? Only want to give it a maximum of about 12 psi. Will it handle it? Thanks.
Car: 1992 B4C 1LE
you may wish to add an FMU and is it a 4BBL unit? or just get the procharger TPI blower kit and the carb hat offered by procharger if you are using the sepentine pulleys. this one pictured uses the GM TBI hat (because of the special studs for a TBI cap).
Car: 1992 B4C 1LE
use a carb kit like this if you are using regular v belts and the FMU added.
509 camaro fan
Sep 6, 2015 10:43 AM
