NOS on a 305 TPI
Old Aug 11, 2002 | 01:08 PM
chevy power's Avatar
NOS on a 305 TPI
i was curious how big of a shot i can run w/ the mods in my sig. the lower end has about 100,000 miles on it now but all the new parts we just put on are in the sig. do i need to redo the lower end before i try to go w/ nitrous or can it handle it on a high milage lower end.
Old Aug 14, 2002 | 06:14 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
keep a stock timing setting and use the only up to the 100hp jets, keep fuel quality high even if it requires a octane booster.
Old Aug 15, 2002 | 05:39 PM
TPI Guy's Avatar
Car: 1968 Camaro
Engine: 406
Transmission: Tremec TKO
Use the biggest shot you can get your hands on with as little fuel as possible, then buy a 350.
Old Aug 15, 2002 | 09:50 PM
5.7L OF JUSTICE's Avatar
Car: 1987 IROC-Z Camaro
Engine: 5.7L TPI
Dont use nitrous at all. We dont need car steroids to run good unlike the little ricers. Just my two cents.
Old Aug 16, 2002 | 06:13 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
your a jack &$$
Old Aug 16, 2002 | 09:11 PM
IROC4LIFE's Avatar
Car: 1986 IROC-Z
Engine: SBC
Transmission: Manual Th-350
Axle/Gears: 9" Moser 3.89's Spool.
NOS
B4Ctom1 is right, you should limit yourself to a 100 shot on a stock 305. Try use the best fuel + octane booster for happy healthy 1/4 mile runs.
If you are running a Stick Shift Car, then you might want to look into an RPM window switch. They provide best results at the 1/4 and the added saftey of having the N20 shut off before the REV limiter.
Orr89RocZ
Apr 25, 2016 08:28 AM
69 Six Pack
Oct 5, 2015 07:51 PM
gta90
Sep 15, 2015 04:00 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
