Cam selection + Nitrous???
Old Aug 16, 2002 | 08:55 AM
berlinetta85's Avatar
I'll be rebuilding my L98 engine in a few months and am purchasing all the parts I need for the rebuild...
New gaskets, aluminum vette heads, slp runners, forged pistons & rods, and the like...
I also plan to be using nitrous as part of my new set up and a new cam is part of the mix. My question is what would you all recomend in the way of a "nitrous friendly cam"???
Any help would be greatly appreciated...
Old Aug 16, 2002 | 09:26 AM
Willie's Avatar
Car: 1987 Z28 Convertible
Transmission: 5-speed
A nitrous friendly cam is similar to a blower friendly grind. You want absolutely zero overlap. The intake valve should close BEFORE the exhaust valve starts to open.
Old Aug 16, 2002 | 09:27 PM
IROC4LIFE's Avatar
Car: 1986 IROC-Z
Engine: SBC
Transmission: Manual Th-350
Axle/Gears: 9" Moser 3.89's Spool.
Nitrous Cams
Comp Cams has a Line of Nitrous HP cams, I have heard they work very well.
If you are planning on stickin to a 125hp shot or less than an Extreme Energy Grind will work also. There are many EX grinds for roller cam TPI motors.
www.compcams.com
Old Aug 17, 2002 | 02:23 AM
JR305's Avatar
How would my cam react to nitrous? 208/221 .474/.510 112 @.05. Would having valve overlap just decrease the power of the nitrous shot.
Old Aug 28, 2002 | 04:41 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
A nitrous friendly cam has less overlap than a cam for the same motor that is only N/A. It also needs to open the exhaust valve sooner.
Generally a nitrous cam has a wider lobe separation spec,
additional exhaust duration and is installed more advanced.
Basicly the intake lobe is the same as for a N/A motor but the exhaust lobe and timing is tweeked to ogment the nitrous.
Jorlain
Oct 8, 2015 01:57 AM
1Aauto
Sponsored Vendors
Oct 5, 2015 03:14 PM
1Aauto
Sponsored Vendors
Oct 5, 2015 03:13 PM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
masonta
Sep 1, 2015 06:40 PM
