Getting somewhere with the car finally
Old Aug 19, 2002 | 10:10 AM
Guido's Avatar
Car: 2000 Trans Am
Took these last evening. Before i can start the car up, I have to do the following:
-header gasket
-drill out some of the header flange bolt holes
-tranny lines
-water lines
-radiator hoses
-intercooler water tank mounting & plumbing
-finish bottom of downpipe
-finish TIG weld downpipe
After that, to DRIVE the car, I need
-driveshaft
-brake master cylinder and lines
-reinstall windshield and drivers seat and seatbelt
Here are the photos I took
Old Aug 19, 2002 | 11:01 AM
BlownBird's Avatar
Guido,
Looks Sweet!!! Did you decide where you are going to put the altenator? And are you going to be able to keep the A/C?
Old Aug 19, 2002 | 06:56 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
Guido,
I can't wait for the results of this project. Just wondering though. Is that light oxidisation on the turbo?
Robert
Old Aug 19, 2002 | 07:44 PM
1982chevycamaroz28's Avatar
well i think to add to ur list is get all the pipes welded before u can actually drive it.
Old Aug 19, 2002 | 08:08 PM
True Power's Avatar
Old Aug 19, 2002 | 09:44 PM
JucinGTA's Avatar
Insert Chubby (here):lala:
Old Aug 20, 2002 | 08:28 AM
Guido's Avatar
Car: 2000 Trans Am
Im putting a window air conditioner inthe passenger side window Don. LMAO!!
Here are a few more photos I took last night of my further downpipe progress. I think Im going to leave it open like this for now so i can concentrate on other ****. I can at least start the car up with the exhaust like this.
Yes that is light oxidation on the turbo. nothing much I can do about it except get it coated. no $ for that right now so I am going to make a shield to go around it.
Old Aug 20, 2002 | 12:44 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
The masses call; "DYNO!-DYNO!-DYNO!" I like the extensive use of band clamps.
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
85Iroc-Z
Aug 13, 2015 01:58 AM
