how to modify tensioner to pull other direction on serpintine--help Jester
Old Sep 7, 2002 | 04:08 PM
superirocz's Avatar
Well i finaly got my turbos for my iroc and started the twin t-bird turbo setup. I need to pull the tensioner apart and reverse its pull just like jester did. How can i take it apart and modify it so it pulls oppisite? I would like to do it in the car so i don't have to pull off the bracket. I don't want to just wing this I will end up with a hole in my fiberglass hood or hurt when that tensioner flies apart.
Old Sep 8, 2002 | 05:10 PM
superirocz's Avatar
Well I got the alternator moved down to where the smog pump was. I pulled the tensioner off still not sure how to make it pull the other way.
Old Sep 8, 2002 | 05:35 PM
Greasemonkey's Avatar
Car: 86 Cutlass
Transmission: 200-4R
Do you have AC? If you don't, why don't you just ditch the whole passenger side bracket and create a new bracket for the alternator?
Old Sep 8, 2002 | 10:20 PM
superirocz's Avatar
The point is to ditch the ac delete pulley on the left top and the alternator on the right top so i can mount the turbos in that area and be able to run 3" down pipes. I now have alot of room to work with just not sure how to disasemble the tensioner. After almost 3yrs of abuse and about 28k miles later the 5 speed broke last night shifting into 3rd. I guess 321rwhp and 390rwtq will do that. stay tuned this should be up and running by the end of october.
Old Sep 9, 2002 | 01:45 PM
scauffiel's Avatar
How 'bout some pix of the alternator move?
S.
Old Sep 9, 2002 | 03:50 PM
superirocz's Avatar
my brothers shop is doing the tensioner tommorow, thanks jester for the email. I have the headers bolted on with no problem, i had to bend the brake lines a little out of the way. I should have the turbos mounted with 3" down pipes by the end of next week. I have a digital camera and will take pics for everyone. The pipe from the header to the turbo is only going to be about 3 inches long and I'am going with a 2.25 pipe from the header to the turbo instead of 2.5. The 3" down pipe on the passenger will be cake the driver side with be a little tight but should work fine.
Old Sep 16, 2002 | 05:11 PM
johnsjj2's Avatar
Car: 1991 Z-28
Transmission: T-5 (gonna buy the farm)
Are you using the S-10 headers like Jester did, or another kind? I am still debating what to use.
Vintageracer
Jan 10, 2020 05:33 PM
dcd2236
Exterior Parts for Sale
Aug 19, 2018 02:27 PM
Infested
May 22, 2018 11:56 PM
zayne0
Aug 24, 2015 07:22 PM
theurge
Aug 21, 2015 12:46 PM
