Quick, dumb, beginner nitrous question.
Old Sep 11, 2002 | 05:26 PM
brian89transam's Avatar
N2O- How long do you push the button?
Stupid question, but I've never seen anyone use nitrous, other than in movies.
When you push the button to initiate the spray of nitrous, how long does it last? A couple seconds? Or do you have to hold the button down? Thanks.
Old Sep 11, 2002 | 09:56 PM
5SIZ's Avatar
Car: 1987 IROC-Z
I don't have nitrouse but what I hear is basically it acts like a switch, when you want to set it off, you press and HOLD the button, then when you want to stop you let go.
you only press the nawz when you are over 3,000 rpms "2,500 is the least"
Old Sep 12, 2002 | 10:46 PM
How long do most people hold it for?
Old Sep 13, 2002 | 05:16 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
the only "switch" you want within arms reach is the arming switch, the activation should be attatched to the throttle to cycle during wide open throttle only.
Old Sep 13, 2002 | 11:34 AM
5SIZ's Avatar
Car: 1987 IROC-Z
you can have it setup so you have a throttle body switch, then it will go off at WOT, but you can have it the other way also.
Old Sep 22, 2002 | 05:17 PM
TTT
Old Sep 22, 2002 | 08:30 PM
Tater13150's Avatar
You can hold the button in for the whole 1/4 mile run, but you can hold the button down for as long as you want as long as you have good fuel pressure.
Old Sep 26, 2002 | 11:07 PM
12 Sec GTA's Avatar
Car: 98 Camaro SS
Transmission: M6
You're thinking that nitrous use is a predetermined length "shot" per button press..
It's not like that at all.
The way the switch works is by allowing power to reach the solenoid(s). When the circuit is completed through the solenoid, it opens(magnetic close system IIRC). When the circuit is broken, the plunger will be drawn in, and the solenoid closes.
For circuit control, there are a number of "breaks" or switches within it.
First: WOT Switch. This switch is either mechanical, or electronic (TPS based) This switch mounts on the tb (or carb) and has an arm that extends and is tripped when WOT status is achieved.
Second: Master Arm switch: This switch is located within the car. This is either a toggle, or a push button. When this is activated, and then the prior (or latter) breaks are met, the system will have a complete circuit, and you will be spraying.
Optional: Window Switch: Electronic switch that monitors vehicle RPMs and will only allow the circuit to be open between a set RPM range (usually around 3k -> 5k rpms)
FPSS: Fuel Pressure Safety Switch... This is a valve that hooks into the main Fuel line, and measures the pressure. If it drops off below the set cutoff pressure, the circuit will close.
Hopefully this helps out.
F-body-fan
Jan 12, 2023 01:49 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
meeklay812
Oct 1, 2015 03:46 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
3.8TransAM
Sep 27, 2015 08:37 PM
