nitrous on my little 305
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
hey guys i just rebuilt my 305 last winter and it has about 5000 miles on it now, still runs really good. it ran a 14.8 @93 mph with a crummy 2.2 60ft. in the summer heat my converter is a little too tight for the cam i am runnin but i plan on swappin in a 6 speed in the future. i am seriously thinkin of adding a 100-125 horse shot to my motor this winter and was wondering what kind of drop in ET i would expect from a 100 horse shot. i may also buy an aftermarket base but not sure if i will have the cash for that yet.
Car: 86 IROC
Engine: 383
thanks for the reply, i wasnt sure. i just wanted a rough estimate of how much time it woudl drop so i know the margin by which i will be smokin my buddies by this spring
Car: 1986 camaro, 1993 nissan altima(winter beater, 1992 mustang (summer daily driver)
Engine: 350tpi
Transmission: 700r4 with shift kit
Hey man what if those buddies of yours have tricks up their sleeves too?Your not the only one whos gonna be sprayin
Car: 86 IROC
Engine: 383
well buttsauce i guess we will find out wont we?
but like i said, i would be darn careful about sprayin on a motor that only has 125psi compression per hole. that is mighty low you will have alot of blow by when you hit the button. nitrous, as with any power adder, will boost cylinder pressures and with already marginal ring seal you wont be helpin things. you better tie the dipstick tube in and tape the pcv and oil cap down, dont belive me? talk to the turbo and blower guys, same thing happens to them too.
but like i said, i would be darn careful about sprayin on a motor that only has 125psi compression per hole. that is mighty low you will have alot of blow by when you hit the button. nitrous, as with any power adder, will boost cylinder pressures and with already marginal ring seal you wont be helpin things. you better tie the dipstick tube in and tape the pcv and oil cap down, dont belive me? talk to the turbo and blower guys, same thing happens to them too. Thread
