Short water pump for Blower motor
Old Sep 18, 2002 | 02:07 PM
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
I did a search, didnt find anything.
I may be adding a 250 CI blower to my car. Holley says Ill need a SHORT WATER PUMP for this to work.
Whats going to happen to my setup if i buy a short water pump? right now I use the 2 V-belt setup, Alternator and power steering pump. will i need new pulleys? will i need to do anything weird?
thanks... this is the only thing scaring me about swapping to a bigger supercharger.
Old Sep 19, 2002 | 12:33 AM
CamaroDriver's Avatar
You'll be better off posting this under the Power Adder board.
There's guys there that use superchargers as pillows when they sleep at night.
Old Sep 20, 2002 | 04:21 PM
breathment's Avatar
Kingtal0n.. I copied this post to the power adder board for ya..
Old Sep 20, 2002 | 06:52 PM
JAY4SPEED's Avatar
King, short water pump are just that {short}. The distance from the face of the pump {where the pulley bolts too} is at a less distance from the engine block as your standard {long} pumps. If i'm not mistaken this will require all new pulleys but i'm not 100% on that.
eightsixseven
Dec 16, 2024 01:50 PM
evilstuie
Jan 9, 2020 08:29 PM
mhatfield 14
Aug 15, 2015 10:47 AM
Street Lethal
Aug 13, 2015 08:28 PM
Street Lethal
Aug 12, 2015 11:33 AM
