Small update
Old Oct 15, 2002 | 09:26 AM
Guido's Avatar
Car: 2000 Trans Am
Small update
Car is running.
Keeps blowing tubes off so not making any "substantial" power yet. Going to try and make it to the track Friday to finish my tuning.
Old Oct 15, 2002 | 11:23 AM
89ProchargedROC's Avatar
lol, substantial power.....get it at a decent a/f ratio and come back and talk to us
Old Oct 15, 2002 | 11:30 AM
LIL QIK's Avatar
What's your version of substantial power. What kind of boost are you reaching when it blows the tubes off.
Old Oct 15, 2002 | 11:36 AM
Guido's Avatar
Car: 2000 Trans Am
Well, it blew the tubing off running 5800 rpms @ 8psi of boost and was over 500 rwhp.
Couldnt keep it on at anything over that. Im building a brace now to hold the tube on at the TB.
Old Oct 15, 2002 | 02:35 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
try a t-bolt clamp so it can dig the rubber into the "dog-knot" on the TB.
Old Oct 15, 2002 | 03:02 PM
dont forget that this was @ a 9.5:1 a/f ratio.....so NOT ANYWHERE IDEAL haha
that thing is gonna make some sick power when tuned....just remember if you dont have the power you think you should be gettting, just up the boost
Old Oct 15, 2002 | 05:07 PM
Guido's Avatar
Car: 2000 Trans Am
It was running 9.5:1 AF ratio because the first time that it blew the tube away from the TB, it pulled the splice that I had in my IAT sensor wires.
It wasnt running with the IAT which is a pretty important sensor with the speed pro ECU.
Hoping that I have all the problems fixed for this week at the track. hehe
Old Oct 15, 2002 | 05:11 PM
87Z-ya's Avatar
Sounds like its turning out sweet. My speed pro only uses the iat in alpha n mode, is that what your using? Or maybe I need to hook my iat up??
Old Oct 15, 2002 | 05:42 PM
True Power's Avatar
500rwhp...how dare you show your face around here. Honestly, what are you thinking? Be gone now, you illegitimate f-body bastardizing outcast
P.S. I hate you. Keep up the great work, and give us some new dyno numbers soon
Old Oct 15, 2002 | 09:47 PM
Blownvette's Avatar
IAT is included in the base calculation performed by The Speed Pro unit in Speed Density so it is critical that a correct reading is given to the computer.
Old Oct 16, 2002 | 12:28 AM
Bad406Z's Avatar
Car: 85 Camaro
Engine: NA
Transmission: NA
Axle/Gears: NA
I have a question, what size tire are you running out back?
Old Oct 16, 2002 | 12:57 AM
TonyC's Avatar
Car: A Camaro
Engine: Weak
Transmission: Weaker
All I can do is look at this and giggle like a little girl
Wow
I am at a loss for words
Holy crap
Awesome keep up the good work and keep us informed!
Wow
Tony
Old Oct 16, 2002 | 10:22 PM
Guido's Avatar
Car: 2000 Trans Am
Another update
We got the brakes lined out with the right fittings on the prop valve. Got my welder back and tacked a tube nut on the pipe and used the old tie rod that I had originally bought for my alternator tensioner.
Here are some pics.
Hope to test them Friday night at the track!
Old Oct 17, 2002 | 01:00 AM
looks good man
Old Oct 17, 2002 | 01:25 AM
83 Crossfire TA's Avatar
What brake MC is that? I've been wondering if I could replace my stock one with one off of a full size truck just because it has the fittings on the other side (the stock f-body one has them on the engine side), but can't seem to find an answer.
Old Oct 17, 2002 | 01:26 AM
Spooled's Avatar
What track ya going to? IRP? I might come if so. I went to US 41 last weekend. Went 11.00 at 124 on 10 lbs on some dirt track tires. Trans is slippin 28 tire, 3.50 gear, 6100 rpm, 124mph.....something doesn't add up. Have ya got the FAST pretty much tuned now? Good luck!
Old Oct 17, 2002 | 01:53 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
yeah guido whats the dope on that MC how'd convert it like that?
Old Oct 17, 2002 | 03:24 PM
Guido's Avatar
Car: 2000 Trans Am
Stephen 87 IROC from the drag racing forum posted how to do it.
take an S10 manual master cylinder and the pushrod assembly. You take and cut down the pushrod and thread one end for a rod end. take the brake pedal out and drill a hole 1" higher than the factory pick point. bolt the rod end through there and adjust till you get good pressure on the brakes. We had to recut my rod once because it wasnt allowing the piston to fully travel and wasnt getting fluid to the back brakes. Fixed that and now we are gold.
Re route your lines and you are done.
Old Oct 17, 2002 | 05:11 PM
SATURN5's Avatar
Car: 84 SVO
Engine: Volvo headed 2.3T
Transmission: WCT5
Axle/Gears: 8.8" 3.73
Hey Guido, I'm getting ready to add in a Wilwood prop valve on my Bu and it looks like your using 1/4" line. Havent had a chance to look for adapters to go from the 1/8th pipe to 1/4 flare, figures the darn thing comes with 1/8th to 1/8th flare, whered ya pick yours up at? thanks, Bob
Old Oct 17, 2002 | 06:13 PM
Bad406Z's Avatar
Car: 85 Camaro
Engine: NA
Transmission: NA
Axle/Gears: NA
Hey Guido what size tires are those out back? Thanks!
Old Oct 17, 2002 | 09:36 PM
Guido's Avatar
Car: 2000 Trans Am
27 x 11.5 15 Hoosier QTP
I got 1/8" NPT to 1/4" inverted flare at auto zone in their little fitting draers under the counter.
Old Oct 17, 2002 | 11:10 PM
Bad406Z's Avatar
Car: 85 Camaro
Engine: NA
Transmission: NA
Axle/Gears: NA
Thanks. For some reason they look so much bigger on your car than mine and I run a MT 28x11.5x15 ET street. Can't wait to see more of your car!!
Old Oct 18, 2002 | 09:37 AM
SATURN5's Avatar
Car: 84 SVO
Transmission: WCT5
thanks Guido...
Old Oct 18, 2002 | 12:03 PM
BlownBird's Avatar
Looks great Guido!
Let us know how it goes tonight at the track.
You and Tory have given me a lot of motivation, I'll be next on the "it's alive list"! Good luck tonight!
Jorlain
Oct 8, 2015 01:57 AM
aharvel50
Sep 21, 2015 07:31 PM
manifoldsrme
Sep 17, 2015 11:40 PM
Mongoose462ci
Sep 16, 2015 11:46 PM
gta892000
Sep 16, 2015 12:37 AM
