Super Ram?
Old Nov 14, 2002 | 12:58 PM
WS6_355_TPI's Avatar
Super Ram?
Ok guys.... gotta local guy that works with sheet metal that said he could make me the plenum for under 300.
I wasnt sure if I should go with this or just save and buy a Stealth Ram.
He plans on taking the stock tubes, cutting them in half, then making brackets so they can bolt and gasket up to the bottom of the custom plenum. So I would have shorter tubes... and he will make the plenum to the spec of an Accel Superram. Think this is a good idea? Will these "half" runners actually work? Or will this combo still choke the motor?
I need to be able to revv up to about 6500.
Old Nov 14, 2002 | 01:17 PM
TBurke's Avatar
Why not go with the Miniram. It will definately suit your needs and is much easier to work on.
Old Nov 14, 2002 | 05:10 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
yeah and its $1100 price tag makes lotsa sense when compared to the $500 stealth ram, but hey atleast the miniram fits under the hood.
Old Nov 15, 2002 | 01:24 AM
Not worried of fitting under the hood... Just need the higher powerband. now is this gunna take TOO much away if I go stroker from my torque?
Old Nov 15, 2002 | 02:11 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
I doubt it, but a mini ram with its non-existent runner length will for sure. The hood clearance is a legitimate concern, but it gives you an excuse to get a cowl.
Linson
Oct 24, 2025 02:00 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
no green
Jan 9, 2016 09:22 PM
mfp189
Sep 27, 2015 09:25 AM
Dragonsys
Sep 25, 2015 03:51 PM
