Building boost bottom end
Old Nov 23, 2002 | 11:10 PM
Iroc n roll's Avatar
I'm doing some research on boosting a 1993 3.1 MPFI engine. I want to build the bottom end to hold about 15psi. I know forged pistons and rods are a must, but can I get away with the stock crank? What should I use to beef this up to handle 15psi (or even more maybe)? Also what would a good compression be to run it on 93 octane? 8:1? Just looking for ideas.
Old Nov 24, 2002 | 02:59 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
the 60 degree GM V6's cranks are notoriously weak. for several years of 2.8 the #1 cause of major engine failure was broken crank.
Old Nov 24, 2002 | 07:27 AM
Boy does that suck
Old Nov 24, 2002 | 07:28 AM
So basically the only thing I can use is the block correct? All new interals are needed?
Old Nov 24, 2002 | 10:59 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
let me offer you the idea of the 3.4HT swap. this engine makes way more HP initially than the 2.8 and 3.1. if you were to build your current motor or the 3.4ht with less boost, you would raise the durability and survivaility of this project. the best 2.8/3.1/3.4 swap and tuning info comes from the S-10 guys check this link. http://www.s-series.org/phpBB/viewforum.php?f=14
Old Nov 24, 2002 | 04:00 PM
This isn't for a Camaro. I'm just curious if there is anything strong on this block. Didn't they come with forged connecting rods?
Old Nov 25, 2002 | 04:31 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
not many cars "dont" have forged rods (1038 or 1040) forged steel that is.
theshackle
Mar 5, 2017 06:37 PM
beastin91rs
Oct 9, 2015 07:38 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
86IROC112
Aug 21, 2015 07:20 PM
