need nos help and testimonys please
Old Nov 28, 2002 | 11:08 PM
canadiangta's Avatar
I have a 88 GTA,350 TPI, ram air, AFPR, Dynamax headers and cat back W/O A.I.R., 42,000 miles.
I know people say you can just put nos on add be fine, but what do you reccomend?
size-100?150?
spark-Retard?Msd?
fuel-bigger pump?injectors?
What would you guys reccomend doing sor safty and max performence(without going wild, cams, head, exc)
Old Dec 1, 2002 | 01:22 AM
Jer82Z28's Avatar
Car: 1987 IROC
Engine: Vortec 350 TPI
Transmission: 7004r
I strongly suggest you read up on nitrous lots before you start playing around. do a search here and even buy a book on nitrous tuning.
that way you will better understand why people retard their timing, buy different spark plugs etc.
good luck! :rockon:
Old Dec 2, 2002 | 05:25 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
good luck! :rockon:
no way go for it, "its only metal"
Old Dec 2, 2002 | 08:05 PM
chevyboy07 91's Avatar
Get a good aftermarket ignition system like an MSD 6AL and an adjuastable timing computer (also MSD) , and coil. you can adjust timing with a turn of the ****. Run a 150 shot and pull maybee 4 degrees...YOU WILL LOVE IT!!!
with mods in my sig and 26" tall slicks, I ran in the 11.70 range many times w/ low 1.6 short times. Bottlw pressure at approx 1000 psi and on a 150 shot.
junior419
Apr 7, 2025 11:35 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
IROCZ1989
Sep 4, 2015 11:54 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
