What plugs to use for nitrous????
Old Nov 30, 2002 | 08:48 PM
83TransAm's Avatar
Car: 1983 Trans Am
Engine: 355 SBC
Transmission: 700R-4
What are a good brand of nitrous plugs? The plugs will be going into a 355 SBC with a 100 shot of nitrous. Thanks!
Steve
Old Nov 30, 2002 | 10:30 PM
Trux's Avatar
Car: grand prix/84 z28
Engine: 4.6 Northstar
Transmission: t-56
Umm...
I have heard alot of good things about NGK. Just remember if you are running boost or nitrous do not use precious metal spark plugs. They store more heat and can cause detonation.
you are subpost to retard timming 5 degrees for every 50 horsepower, I think.
good luck
Old Dec 1, 2002 | 01:37 PM
MdFormula350's Avatar
i heard that the plantinums are not a good choice..
Old Dec 1, 2002 | 03:34 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
Re: Umm...
It's supposed to be 2 degrees for every 50 hp.
I use ac delco for my engine with nitrous and have had good luck with them.
Old Dec 2, 2002 | 05:21 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
yes avoid platinum or other special metal plugs that use tiny slugs of "special" metal welded to the electrodes, also plugs with sharp electrodes that can cause hotspots, like the 4 tiny electrodes on the bosch +4's, also the splitfires, and the rapidires too although some still use them. Strangely, the U-groove accels and U-groove NGKs seem to do really well though.
Old Dec 2, 2002 | 10:27 PM
Ryche400's Avatar
Try some NGK UR5. Anything colder will affect your performance on motor. If there are O'Reilly Auto parts near you they carry them in stock. I am usually pretty good at recomending plugs if I know what your setup is. I've sold NGK plugs for just about any application you can think of, from 16 sec cars to 8 second cars. If you have any questions, I will be glad to answer any questions.
Old Dec 3, 2002 | 12:02 AM
scorp508's Avatar
Car: Corvettes
Engine: Modified L98 & LT5
Transmission: DN 4+3 & ZF6
Axle/Gears: 3.07 & 4.10
Re: Umm...
Yes, 2* of timing for every 50hp. NX claims their kit does not need this, but I do it anyways. I am running whatever it was that superceedes the FR1LS AC Delco plug. I can't remember the superceeding part # right now. This is 2 steps colder than the plug that originally came in my car.
wigmobile
Feb 26, 2025 02:56 PM
gta892000
Aug 11, 2019 11:16 AM
Jlanz55
Sep 9, 2015 09:09 AM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
89 formula TPI
Sep 7, 2015 11:06 AM
