Heads, Cam, Intake, Computer Questions
Old Dec 3, 2002 | 06:01 PM
Justin91RS305's Avatar
I have a 91 350 TPI.
Questions I have are what would be a good set of heads for my car, I've searched and searched and can't really find a good answer. With Heads, I might as well put in a cam also, so what would be a good one? Also, what is the difference if port the heads myself over buying new heads and then maybe porting then. If I put heads and a cam in, will I need to have a custom burned PROM made? How much can I do before I need to have a custom burned PROM.
Would these heads be usable if I decide to put a supercharger on in a few years or so?
Current engine has 119K, but runs strong and has 175psi when I did the compression check.
If I try to port my intake, I read that somebody ported too much, said he ran a cylinder too lean, and burned up the engine, is that possible?
Thanks for the help. I've tried to search for these answer, and I have come up short.
Justin
Frozer!!!
Jan 19, 2024 04:55 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
86White_T/A305
Aug 17, 2015 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
TreDeClaw
Aug 14, 2015 06:58 PM
