Where can I buy a check valve?
Old Dec 4, 2002 | 10:03 AM
TransAm86's Avatar
To put between my intake and MAP sensor. This is for running a supercharger using Speed Density.
I know of a kit,
http://www.proficientperformance.co...Code=A10261-011
But it really seems like a ripoff for 140$.
I searched the posts and found out you could fabrivate one yourself with a t fitting and a check valve on one end?
Thanks,
Nik
Old Dec 4, 2002 | 10:41 AM
Bobalos's Avatar
I bet that you can find something to work @ http://www.mcmaster.com/
BW
Old Dec 4, 2002 | 10:52 AM
TransAm86's Avatar
Thanks!!!
Now How many PSI is 1 BAR?
Nik
Old Dec 4, 2002 | 11:03 AM
TransAm86's Avatar
Never mind! I found out its more that 11,5 psi.
Here's my situation. I want to install an A-Trim (around 6psi max) on my Speed Density '87 Mustang. The problem is that around 3500rpm the engine will bogg and I might also experience idle problems due to the MAP sensor not beeing able to read boost. In order to rectify the situation, I need to install a check valve on the vaccum hose between my intake and MAP sensor.
EDIT... Note: Under boost the FMU will variate the fuel pressure.
My question is, what cracking pressure should my valve have? A low one like 0.8 psi or higher like 2, 3 or 4 psi?
thanks,
Nik
Old Dec 4, 2002 | 12:17 PM
Monty's Avatar
Car: Old Car - 1982 Vette. New Car - 1972 Vette Convertible
Engine: Old Car - 1200hp TTSBC 427. New Car - TT LS7X
Transmission: Old Car - 4L80E. New Car - TBD
Will a 2-bar MAP sensor work with your ECM? Might be a dumb question, I'm just not very familiar with the details of Ford ECM's.
Old Dec 4, 2002 | 01:19 PM
TransAm86's Avatar
I dont know if a 2 BAR MAP would work with my ECM, but if I where to do that, I might as well convert to MAF. I think GM has 2 and 3 BAR MAP's, right? As for for fords this is the only way I eard it was possible to resolve this problem. Seems it works on some engines and some other ones are more stuborn. In this case a MAF conversion is necessary. Its not that expensive.
I just wanted to know if I should buy a valve with very low cracking pressure to make sure the MAP doesn't need to read any positive pressure?
Old Dec 4, 2002 | 01:39 PM
Monty's Avatar
I understand that you will use an FMU to provide fuel enrishment under boost, even with the MAP 'blocked', but how will control timing retard? MSD BTM?
backtothe80s
Sep 5, 2015 12:39 AM
1985chevydude
Aug 20, 2015 12:29 AM
Out-Cast
Aug 17, 2015 10:57 AM
86White_T/A305
Aug 17, 2015 12:16 AM
