T-76 Turbo a/r .96/.72. good for SBC?
Old Dec 23, 2002 | 11:45 AM
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
Found another turbo, curious about these things.
T-76 a/r .96/.72.
What the heck are those numbers? it ALMOST sounds too darn big... evem though i know little the T-76 sounds bigger than a T-3 lol.
Old Dec 23, 2002 | 02:02 PM
83 Crossfire TA's Avatar
T76 is the compressor size, which is fine for most small blocks. The AR is the turbine size, the smaller the # the smaller the turbine. Why you've got 2 A/R #'s I don't know
Old Dec 23, 2002 | 10:20 PM
Kingtal0n's Avatar
Transmission: 4l80e
Axle/Gears: 3.512
so what would be a reasonable price for a rebuilt turbo like that? $1000? $500?
Old Dec 24, 2002 | 12:59 AM
Donno, but I did see a newish one (supposely a few hundered miles before the guy descided that he didn't like how it spooled on his GN) for $700 on the turbotraider a couple of months ago
Old Dec 24, 2002 | 03:46 AM
89ProchargedROC's Avatar
a rebuild is easy and can be done at home.
or if you really want to send it out, usually $250 plus shipping
Old Dec 30, 2002 | 08:49 AM
WickedTwinTurbo's Avatar
T76 is worth about $1250.00 new. 76 simply means that the compressor wheel is 76mm they normalLy a P or Q trim on the exhaust side and it is a big shaft turbo (more money).The a/r is size of the exhaust housing. The bigger it is you need more exhaust for spool up.96 is a common size housing which will work fine with a SBC. I have never seen a housing with two different a/r. maybe he has two different a/r exhaust housings. When my TA was a single turbo it had a 60-1 turbo with .96 a/r housing with p trim exhaust wheel. now I have two Hi fi 60-1 turbos with .59 a/r exhaust housing. On my GN the stock factory size a/r was .63 three bolt exhaust housing, but I run a .81a/r exhaust housing 4 bolt with 70mm compressor wheel. the car has a little more lag compared to the .63 stock setup but with a higher stall coverter and good heads I was able to over come that and have great top end due to the reduced back pressure. When I switched from a .63 a/r to .81a/r my GN went .3 sec 3mile/hr faster.
Good luck
Prasad
Old Dec 30, 2002 | 03:39 PM
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
If it has a .96 your gonna need some serious exhaust pressure to spin that sucker up without a healthy stall. If you have a choice go with the .72. It'll spool quicker and make it more drivable with a lower stall.
Old Dec 30, 2002 | 06:10 PM
Bobalos's Avatar
IIRC, Guido is running a .96 AR on his PT88 on his Single. I think though that he is running a TH400, on his Big SBC. I would be interested in knowing what stall he is going to run (Guido??).
BW
Old Dec 30, 2002 | 09:19 PM
PETE's Avatar
Car: 1989 TTA #1240
Transmission: 2004r
Regardless of the stall Guido has an advantage! More cylinder volume(large bore SBC) which equates to more exhaust gases to spool the turbo. He could theoretically get away with a smaller stall converter than an evenly modded 350.........
Old Dec 30, 2002 | 09:48 PM
Kingtal0n's Avatar
Transmission: 4l80e
Axle/Gears: 3.512
SO technically its better to have two smaller turbos than one big one? faster boost and more of it? I always thought 1 big turbo was the way to go for max HP... and twins were good for the street. is this true?
Old Dec 31, 2002 | 01:13 AM
With the PT88 that guido runs....the reccomended stall is in the 4500range. I believe he is running a 8" 5000rpm converter from coan.
Twins are more forgiving for making huge power at streetable RPM levels yes.....at least IMO
Old Dec 31, 2002 | 01:44 AM
Yes
No
Maybe…
Yes - The inertia of the compressor/turbine assembly is proportionate to the ^4 of the radius, so a turbo with a slightly smaller major diameter will spool more easily, as will 2 substantially smaller turbos compared to a large single.
No - OTOH, how well a turbo spools is also highly dependant on the plumbing. Optimum for a small t3 on one bank is probably something along the lines of an exhaust manifold with as low a volume as possible that retains as much heat as possible and then a down pipe in the 3” range. Smaller downpipes will work and make similar power but the turbo will be slower to spool. I haven’t seen anyone running bigger then a 2.5” down pipe with twins on an f-body, it’s just very difficult to fit.
Maybe - it really comes down to the packaging and parts selection, you can’t say that one will spool better then the other without taking that + other things like cam selection into account. Smaller twins will be more likely to spool quickly. OTOH, how quickly do you really want them to spool? In a perfect world you’d be able to put down all the power you manage to make at any instant, but in the real world, you’re talking about a good size V8 that’s going to have a tendency of making an abundance of low end without the turbo… a little bit of sluggishness in the spooling will help make the car driveable.
Old Dec 31, 2002 | 02:47 PM
Bobalos's Avatar
More Cly volume than what? I dont see a motor size here except for what you put. dont get me wrong, we are on the same page, this is all about relativity. too big a turbo only means that we are building to small a motor Heck get two of them & build a MUCH larger motor & call it done.
a 5K stall converter on a large SBC is a lot of air, gotta love that!
BW
Old Dec 31, 2002 | 03:09 PM
PETE's Avatar
Car: 1989 TTA #1240
Transmission: 2004r
I assumed in his sig it was a 355. The voulume of cylinder A(355) v/s the volume of cylinder B(406). Being that there will be more gases from the larger engine it would be easier to spool a larger turbo compared to the 355. That's all I meant.........
Terrell351
Jun 13, 2021 01:13 PM
camaro71633
Sep 1, 2015 10:24 AM
Wesly_66
Aug 26, 2015 09:55 PM
theurge
Aug 21, 2015 12:46 PM
LT1Formula
Aug 20, 2015 09:36 PM
