Twin turbo TPI
Old Dec 29, 2002 | 12:18 PM
87transam5.7tpi's Avatar
Twin turbo TPI
I am thinking about doing a S/C or a Twin Turbo set up for my trans am. and was just wonering what all would I need to do differently as far the computer w/ a S/C compared toa TT setup. also would two turbos be better than one S/C ? I'm looking at around 10-15 PSI of boost depends what gas I'm running etc.
thanks
Josh
P.S. I did a search but couldn't find anything
Old Dec 29, 2002 | 01:19 PM
SATURN5's Avatar
Car: 84 SVO
Engine: Volvo headed 2.3T
Transmission: WCT5
Axle/Gears: 8.8" 3.73
Re: Twin turbo TPI
thanks
Josh
Either will require a change.
1 Use a FMU to raise fuel pressure.
2 Swap to a 749. http://www.speedtoys.com/~bort62/7749/Index.htm
3 Go with DFI.
Supercharger is a bolt on with the proper kit. TT will require lots of time and skill as there is not a thirdgen kit atm. You will have to build it yourself. Of course you knew that since you did a search...
Old Dec 29, 2002 | 01:28 PM
well I have two turbos laying around to get everything going. they have both been rebuilt and I was jsut thinking it would be cheaper to do TT than a S/C for $4000 for the kit w/ everything. and I know how to burn my own proms so that wouldn't be an issue. thanks for the help
Old Dec 29, 2002 | 02:09 PM
SATURN5's Avatar
Car: 84 SVO
Transmission: WCT5
If you already have the turbos, then check out posts by bhaas. In fact he may a set of headers to sell. Log style seems to work fine for most applications. At 10-15 lbs of boost a intercooler would be a good idea. Will it be cheaper to build then a SC is all relevent on what materials you use and how much you do on your own or pay someone else to do. My twin Eaton setup has cost about 800 to build. But I have done all the fabrication.
If you are proficiant at prom burning then the 749 would be your best option. It will control what you need and has the option of using P/H injectors with a change of the mosfet (injecter) drivers. SyTY guys are using +72 lb P/H with modified 749 ECMS.
Old Dec 30, 2002 | 11:02 AM
I will be building everything myself. I have the resources and time so the only costs would be parts. and can you run a TT setup through one intercooler? thanks
Old Dec 30, 2002 | 03:35 PM
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
As long as the IC is large enough to handle the heat exchange. One benefit the camaros have that the t/a's don't is an open grille, you'll be able to get the air flowing across the IC well in a camaro....................................
bjpotter
Jan 22, 2019 12:27 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
1986Z28OWNER
Dec 13, 2015 10:19 PM
86White_T/A305
Aug 17, 2015 12:16 AM
Sanjay
Aug 12, 2015 03:41 PM
