Supercharger Help Please
Old Jan 6, 2003 | 01:39 AM
unknown_host's Avatar
Car: 1989 Iroc Z L98
Hey I need some help, last time i posted it turned into a roots vs centrifigal argument.
Anywho, I have a vortec headed 350HO i plan on putting either the Vortec carb SBC kit on or more than likely the ATI pro charger sbc carb kit with the P1SC upgrade. I have a few questions tho:
Which kit do you guys prefer? Roots is out of the question, i dont want to adapt it to vortec heads and I have no hood clearance as it is. Plus i like the stockish look of centrifigal.
Also, my main question is how does the mechanical fuel pump know to increase fuel pressure when boost is added? ATI had a diagram showing an air tube running from the front of the carb (vacuum???) to the fuel pump. Any help? Finally, what should I do to the carb?
Thanks guys,
Seth
Old Jan 6, 2003 | 05:49 PM
BTTT Nobody?
Old Jan 9, 2003 | 03:13 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
if you wait just a bit longer the vortec bases for roots are just around the corner (any day now probably). Otherwise this will be a post about how you wish you had waited so you could have made it so much easier on yourself. I will check my connections.
InfinityShade
Feb 21, 2016 01:29 PM
toronto formula
Nov 10, 2015 06:17 AM
-=Z28=-
Sep 24, 2015 10:21 AM
anesthes
Aug 24, 2015 08:32 AM
PestilenceIV
Aug 20, 2015 03:32 PM
